r17037 - Avoid undefined behaviour in next_float functions (Raúl Marín)
Raul raul at rmr.ninja
Wed Nov 21 03:45:43 PST 2018
Author: algunenano
Date: 2018-11-21 03:45:43 -0800 (Wed, 21 Nov 2018)
New Revision: 17037
   branches/2.5/NEWS
   branches/2.5/liblwgeom/cunit/cu_libgeom.c
   branches/2.5/liblwgeom/lwgeom_api.c
References #4247
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2018-11-21 11:43:57 UTC (rev 17036)
+++ branches/2.5/NEWS	2018-11-21 11:45:43 UTC (rev 17037)
@@ -1,3 +1,9 @@
+PostGIS 2.5.2
+XXXX/XX/XX
+ * Bug fixes *
+  - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
 PostGIS 2.5.1
 2018/11/18
@@ -19,7 +25,7 @@
   - #4216, Revert non-sliced box access (Paul Ramsey)
   - #2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
   - #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
-  - #4190, Avoid undefined behaviour in gserialized_estimate
+  - #4190, Avoid undefined behaviour in gserialized_estimate (Raúl Marín)
 PostGIS 2.5.0
Modified: branches/2.5/liblwgeom/cunit/cu_libgeom.c
--- branches/2.5/liblwgeom/cunit/cu_libgeom.c	2018-11-21 11:43:57 UTC (rev 17036)
+++ branches/2.5/liblwgeom/cunit/cu_libgeom.c	2018-11-21 11:45:43 UTC (rev 17037)
@@ -688,6 +688,26 @@
 	f = next_float_up(d);
 	d = next_float_up(f);
 	CU_ASSERT_DOUBLE_EQUAL(f,d, 0.0000001);
+	d = DBL_MAX;
+	f = next_float_up(d);
+	d = next_float_up(f);
+	CU_ASSERT_DOUBLE_EQUAL(f, d, 0.0000001);
+	d = DBL_MAX;
+	f = next_float_down(d);
+	d = next_float_down(f);
+	d = -DBL_MAX;
+	d = -DBL_MAX;
Modified: branches/2.5/liblwgeom/lwgeom_api.c
--- branches/2.5/liblwgeom/lwgeom_api.c	2018-11-21 11:43:57 UTC (rev 17036)
+++ branches/2.5/liblwgeom/lwgeom_api.c	2018-11-21 11:45:43 UTC (rev 17037)
@@ -51,7 +51,12 @@
 inline float
 next_float_down(double d)
-	float result  = d;
+	float result;
+	if (d > (double)FLT_MAX)
+		return FLT_MAX;
+	if (d <= (double)-FLT_MAX)
+		return -FLT_MAX;
+	result = d;
 	if ( ((double)result) <=d )
 		return result;
@@ -67,7 +72,12 @@
 inline float
 next_float_up(double d)
-	float result  = d;
+	float result;
+	if (d >= (double)FLT_MAX)
+		return FLT_MAX;
+	if (d < (double)-FLT_MAX)
+		return -FLT_MAX;
+	result = d;
 	if ( ((double)result) >=d )
 		return result;
