[postgis-tickets] [PostGIS] #4249: Undefined behaviour in test_raster_intersects
trac at osgeo.org
Wed Nov 21 04:29:18 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: raster | Version: trunk
Keywords: |
Looks line a division by zero:
Program terminated with signal SIGILL, Illegal instruction.
#0 0x0000557e97351799 in rt_raster_intersects_algorithm
(rast1=0x557e97c6d810, rast2=0x557e97c6a130, band1=0x557e97cf00e0,
band2=0x557e97cdfac0, hasnodata1=1, hasnodata2=1, nodata1=0,
nodata2=0) at rt_spatial_relationship.c:722
722 else if (FLT_EQ(((line1[Y2] - line1[Y1]) / (line1[X2] -
line1[X1])), ((line2[Y2] - line2[Y1]) / (line2[X2] - line2[X1]))))
(gdb) p line1
$1 = {-1, -1, -1, 1}
(gdb) p line2
$2 = {0, 0, 2, 0}
(gdb) bt
#1 0x0000557e97350d23 in rt_raster_intersects (rast1=0x557e97c6d810,
nband1=0, rast2=0x557e97c6a130, nband2=0, intersects=0x7fff86403344)
at rt_spatial_relationship.c:1276
#2 0x0000557e97329e20 in test_raster_intersects () at
cu_spatial_relationship.c:4323
#3 0x00007f27df460118 in ?? () from /usr/lib/libcunit.so.1
#4 0x00007f27df4603b2 in ?? () from /usr/lib/libcunit.so.1
#5 0x00007f27df4607b7 in CU_run_all_tests () from /usr/lib/libcunit.so.1
#6 0x0000557e97349865 in main (argc=1, argv=0x7fff864036c8) at
cu_tester.c:103
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4249>
