[postgis-tickets] r16797 - Avoid detail about which VCS is in use
Sandro Santilli strk at kbt.io
Fri Sep 14 08:16:19 PDT 2018
Author: strk
Date: 2018-09-14 08:16:19 -0700 (Fri, 14 Sep 2018)
New Revision: 16797
   trunk/doc/installation.xml
Drops SVN mentions from installation docs
[ci skip]
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml	2018-09-14 15:03:56 UTC (rev 16796)
+++ trunk/doc/installation.xml	2018-09-14 15:16:19 UTC (rev 16797)
@@ -579,9 +579,9 @@
 	  </variablelist>
 	  <note>
 		<para>
-		  If you obtained PostGIS from the SVN
-		  <ulink url="http://svn.osgeo.org/postgis/trunk/">
-			repository
+		  If you obtained PostGIS from the
+		  <ulink url="https://trac.osgeo.org/postgis/wiki/CodeRepository">
+			code repository
 		  </ulink>
 		  , the first step is really to run the script
 		</para>
@@ -1928,7 +1928,7 @@
     <programlisting>Version "&last_release_version;" of extension "postgis" is already installed</programlisting>
     <para>
 Then everything is already up to date and you can safely ignore it. <emphasis role="bold">UNLESS</emphasis>
-you're attempting to upgrade from an SVN version to the next (which
+you're attempting to upgrade from an development version to the next (which
 doesn't get a new version number); in that case you can append "next" to the version
 string, and next time you'll need to drop the "next" suffix again:
     </para>
