[postgis-tickets] r16798 - Use qualified names in topology extension install
Raul
raul at rmr.ninja
Fri Sep 14 08:30:20 PDT 2018
Author: algunenano
Date: 2018-09-14 08:30:20 -0700 (Fri, 14 Sep 2018)
New Revision: 16798
branches/2.2/NEWS
branches/2.2/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
References #4160
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2018-09-14 15:16:19 UTC (rev 16797)
+++ branches/2.2/NEWS 2018-09-14 15:30:20 UTC (rev 16798)
@@ -1,3 +1,10 @@
+PostGIS 2.2.8
+2018/09/14
+ * Bug Fixes *
+ - #2985, Avoid array overflow in ANALYZE (Paul Ramsey)
+ - #4160, Use qualified names in topology extension install (Raúl Marín)
PostGIS 2.2.7
2018/04/06
Modified: branches/2.2/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
--- branches/2.2/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in 2018-09-14 15:16:19 UTC (rev 16797)
+++ branches/2.2/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in 2018-09-14 15:30:20 UTC (rev 16798)
@@ -1,2 +1,2 @@
-SELECT pg_catalog.pg_extension_config_dump('topology', '');
-SELECT pg_catalog.pg_extension_config_dump('layer', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
