[postgis-tickets] r17662 - Fix minor version check issue in protobuf configuration
Paul Ramsey
pramsey at cleverelephant.ca
Fri Aug 2 09:32:44 PDT 2019
Author: pramsey
Date: 2019-08-02 09:32:44 -0700 (Fri, 02 Aug 2019)
New Revision: 17662
branches/2.4/configure.ac
Modified: branches/2.4/configure.ac
--- branches/2.4/configure.ac 2019-08-02 16:32:02 UTC (rev 17661)
+++ branches/2.4/configure.ac 2019-08-02 16:32:44 UTC (rev 17662)
@@ -976,7 +976,7 @@
HAVE_PROTOBUF=no
else
dnl Ensure libprotobuf-c is of minimum required version
- PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.1.0], [
+ PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c], [
HAVE_PROTOBUF=yes;
PROTOBUF_CPPFLAGS=$PROTOBUFC_CFLAGS;
PROTOBUF_LDFLAGS=$PROTOBUFC_LIBS
@@ -988,7 +988,7 @@
if test "$HAVE_PROTOBUF" = "yes"; then
AC_PATH_PROG(PROTOCC, protoc-c)
if test "x$PROTOCC" = "x"; then
- AC_MSG_WARN([Protobuf compiler missing, disabling protobuf support.])
+ AC_MSG_WARN([Protobuf compiler not in path, disabling protobuf support.])
HAVE_PROTOBUF=no
else
AC_DEFINE([HAVE_LIBPROTOBUF], [1], [Define to 1 if libprotobuf-c is present])
