[postgis-tickets] [PostGIS] #4469: ST_ConcaveHull Runtime
trac at osgeo.org
Fri Aug 2 12:32:12 PDT 2019
Reporter: tsw | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.5.x
Keywords: |
A concave hull query with the attached data set under Postgresql 9.4 /
PostGIS 2.2 / Geos 3.5.0 runs in under a second.
The same query using the same data on Postgresql 9.6 / PostGIS 2.5.2 /
GEOS 3.7.1 is still running after 30 minutes.
I've also attached a perf top screen shot to help people identify the
possible source of the problem.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4469>
