[postgis-tickets] r17711 - Reorganize protobuf detection so that separate directories can be specified, and make version detection more robust over different protobuf installs.
Paul Ramsey pramsey at cleverelephant.ca
Wed Aug 14 03:07:41 PDT 2019
Author: pramsey
Date: 2019-08-14 15:07:40 -0700 (Wed, 14 Aug 2019)
New Revision: 17711
   trunk/configure.ac
   trunk/postgis/Makefile.in
   trunk/postgis/postgis_libprotobuf.c
   trunk/postgis_config.h.in
   trunk/regress/core/Makefile.in
   trunk/regress/core/geobuf.sql
   trunk/regress/core/geobuf_expected
   trunk/regress/core/mvt.sql
   trunk/regress/core/mvt_expected
References #4481
Modified: trunk/configure.ac
--- trunk/configure.ac	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/configure.ac	2019-08-14 22:07:40 UTC (rev 17711)
@@ -973,95 +973,103 @@
 dnl ===========================================================================
 CHECK_PROTOBUF=yes
-HAVE_PROTOBUF=no
+HAVE_PROTOBUF=yes
 AC_ARG_WITH([protobuf],
 	[AS_HELP_STRING([--without-protobuf], [build without protobuf-c support])],
 	[CHECK_PROTOBUF="$withval"], [])
-dnl User didn't turn off protobuf support so...
+dnl User didn't turn OFF protobuf support so...
 if test "$CHECK_PROTOBUF" != "no"; then
-    AC_ARG_WITH([protobufdir],
-    	[AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],
-    	[PROTOBUFDIR="$withval"], [PROTOBUFDIR=])
+	dnl Need to find libdir, incdir and protoc-c compiler
-    dnl User specified the directory to find protobuf in, check that and
-    dnl fail if it doesn't work
-    if test ! "x$PROTOBUFDIR" = "x"; then
-    	dnl Make sure that the directory exists
-    	if test "x$PROTOBUFDIR" = "xyes"; then
-    		AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/path/to])
-    	else
-    		AC_MSG_RESULT([Using user-specified protobuf-c directory: $PROTOBUFDIR])
+	CPPFLAGS_SAVE="$CPPFLAGS"
+	LDFLAGS_SAVE="$LDFLAGS"
-    		dnl Add the include directory to PROTOBUF_CPPFLAGS
-    		PROTOBUF_CPPFLAGS="-I$PROTOBUFDIR/include"
-    		PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib"
-    	fi
+	dnl Try pkgconfig first
+	if test -n "$PKG_CONFIG"; then
+		dnl Ensure libprotobuf-c is of minimum required version
+		PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.0.0], [
+				PROTOBUF_CPPFLAGS="$PROTOBUFC_CFLAGS";
+				PROTOBUF_LDFLAGS="$PROTOBUFC_LIBS";
+				AC_MSG_RESULT([libprotobuf-c not found in pkg-config])
+	fi
-        dnl Check that we can find the protobuf/protobuf.h header file
-        CPPFLAGS_SAVE="$CPPFLAGS"
-        CPPFLAGS="$PROTOBUF_CPPFLAGS"
-        AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
-		    AC_MSG_ERROR([unable to find $PROTOBUFDIR/include/protobuf-c/protobuf-c.h])
-        CPPFLAGS="$CPPFLAGS_SAVE"
+	AC_ARG_WITH([protobufdir],
+		[AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],[
+			if test "x$withval" = "xyes"; then
+				AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/usr/local])
+			else
+				PROTOBUF_LDFLAGS="-L$withval/lib -lprotobuf-c";
+				PROTOBUF_CPPFLAGS="-I$withval/include"
+			fi
-        dnl Ensure we can link against libprotobuf-c
-        LIBS_SAVE="$LIBS"
-        LIBS="$PROTOBUF_LDFLAGS"
-        AC_CHECK_LIB([protobuf-c], [protobuf_c_message_check], [],
-            AC_MSG_ERROR([unable to link protobuf-c from $PROTOBUFDIR/lib])
-        HAVE_PROTOBUF=yes
-        PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib -lprotobuf-c"
-        LIBS="$LIBS_SAVE"
+	AC_ARG_WITH([protobuf-inc],
+		[AS_HELP_STRING([--with-protobuf-inc=PATH], [google/protobuf-c/protobuf-c.h header installation directory])], [
+			PROTOBUF_CPPFLAGS="-I$withval"
-    dnl No user-specified protobuf dir, try to find one using pkg-config
-    else
-        if test -z "$PKG_CONFIG"; then
-        	AC_MSG_WARN([Cannot find pkg-config, disabling protobuf support.])
-        	HAVE_PROTOBUF=no
-        else
-        	dnl Ensure libprotobuf-c is of minimum required version
-        	PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.1.0], [
-                    HAVE_PROTOBUF=yes;
-                    PROTOBUF_CPPFLAGS=$PROTOBUFC_CFLAGS;
-                    PROTOBUF_LDFLAGS=$PROTOBUFC_LIBS
-                [HAVE_PROTOBUF=no])
-        fi
-    fi
+	AC_ARG_WITH([protobuf-lib],
+		[AS_HELP_STRING([--with-protobuf-lib=PATH], [libprotobuf-c.so/dll/dylib library installation directory])], [
+			PROTOBUF_LDFLAGS="-L$withval -lprotobuf-c"
-    if test "$HAVE_PROTOBUF" = "yes"; then
-    	AC_PATH_PROG(PROTOCC, protoc-c)
-    	if test "x$PROTOCC" = "x"; then
-    	  AC_MSG_WARN([Protobuf compiler missing, disabling protobuf support.])
-    	  HAVE_PROTOBUF=no
-    	else
-    	  AC_DEFINE([HAVE_LIBPROTOBUF], [1], [Define to 1 if libprotobuf-c is present])
-    	fi
-    fi
+	if test -n "$PROTOBUF_CPPFLAGS"; then
+		CPPFLAGS="$PROTOBUF_CPPFLAGS"
+	fi
-    dnl Get version number for protoc-c
+	if test -n "$PROTOBUF_LDFLAGS"; then
+		LDFLAGS="$PROTOBUF_LDFLAGS"
+	fi
+	dnl confirm that discovered/configured include path works
+	AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
+		AC_MSG_RESULT([unable to find protobuf-c/protobuf-c.h using $CPPFLAGS])
+		HAVE_PROTOBUF=no
+	dnl confirm that discovered/configured library path works
+	AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init], [],
+		AC_MSG_RESULT([unable to link protobuf-c using $LDFLAGS])
+		HAVE_PROTOBUF=no
+	AC_CHECK_LIB([protobuf-c], [protobuf_c_version],
+		AC_DEFINE([HAVE_PROTOBUF_C_VERSION], [1], [Define to 1 if protobuf_c_version() is present]),
+	AC_MSG_CHECKING([protobuf-c version])
+	AC_PROTOBUFC_VERSION([PROTOC_VERSION])
+	AC_MSG_RESULT([$PROTOC_VERSION])
+	CPPFLAGS="$CPPFLAGS_SAVE"
+	LDFLAGS="$LDFLAGS_SAVE"
+	dnl confirm that protobuf compiler is available
+	AC_PATH_PROG(PROTOCC, protoc-c)
+	if test -z "$PROTOCC"; then
+		AC_MSG_RESULT([Cannot find protoc-c protobuf compiler on the PATH: $PATH])
+		HAVE_PROTOBUF=no
+	fi
+	dnl all tests passed! turn on compile-time defines
-        PROTOCC_SEMVER=$($PROTOCC --version | grep protobuf-c | awk '{print $2}')
-        AC_MSG_RESULT([checking protoc-c version... $PROTOCC_SEMVER])
-        PROTOCC_VERSION_MAJOR=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $1}')
-        PROTOCC_VERSION_MINOR=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $2}')
-        PROTOCC_VERSION_PATCH=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $3}')
-        PROTOCC_VERSION=$(expr 10000 \* $PROTOCC_VERSION_MAJOR + 100 \* $PROTOCC_VERSION_MINOR + $PROTOCC_VERSION_PATCH)
-        if test $PROTOCC_VERSION -ge 10100; then
-            AC_DEFINE([HAVE_GEOBUF], [1], [Define to 1 if libprotobuf-c is >= 1.1])
-        fi
-    fi
+		AC_DEFINE([HAVE_LIBPROTOBUF], [1], [Define to 1 if libprotobuf-c is present])
+		AC_DEFINE_UNQUOTED([LIBPROTOBUF_VERSION], [$PROTOC_VERSION], [Numeric version number for libprotobuf-c])
+		if test $PROTOC_VERSION -ge 1001000; then
+			AC_DEFINE([HAVE_GEOBUF], [1], [Define to 1 if libprotobuf is >= 1.1])
+		fi
+	fi
-    AC_SUBST([PROTOCC_VERSION])
+    AC_SUBST([HAVE_PROTOBUF])
+    AC_SUBST([PROTOC_VERSION])
     AC_SUBST([PROTOBUF_CPPFLAGS])
     AC_SUBST([PROTOBUF_LDFLAGS])
-    AC_SUBST([HAVE_PROTOBUF])
 fi
@@ -1642,9 +1650,9 @@
 AC_MSG_RESULT([  Libxml2 version:      ${POSTGIS_LIBXML2_VERSION}])
 AC_MSG_RESULT([  JSON-C support:       ${HAVE_JSON}])
-AC_MSG_RESULT([  protobuf-c support:   ${HAVE_PROTOBUF}])
+AC_MSG_RESULT([  protobuf support:     ${HAVE_PROTOBUF}])
 if test "x$HAVE_PROTOBUF" = "xyes"; then
-  AC_MSG_RESULT([  protobuf-c version:   ${PROTOCC_SEMVER}])
+  AC_MSG_RESULT([  protobuf version:     ${PROTOC_VERSION}])
 fi
 AC_MSG_RESULT([  PCRE support:         ${HAVE_PCRE}])
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/postgis/Makefile.in	2019-08-14 22:07:40 UTC (rev 17711)
@@ -58,7 +58,7 @@
 ifeq (@HAVE_PROTOBUF@,yes)
 PROTOBUF_OBJ = vector_tile.pb-c.o
-ifeq ($(shell expr @PROTOCC_VERSION@ ">=" 10100),1)
+ifeq ($(shell expr @PROTOC_VERSION@ ">=" 1001000),1)
 PROTOBUF_OBJ += geobuf.pb-c.o
 endif
 UTHASH_INCLUDE = -I../deps/uthash/include
@@ -223,7 +223,7 @@
 lwgeom_out_mvt.o: vector_tile.pb-c.h
+ifeq ($(shell expr $(PROTOC_VERSION) ">=" 1001000),1)
 lwgeom_out_geobuf.o: geobuf.pb-c.h
 endif
Modified: trunk/postgis/postgis_libprotobuf.c
--- trunk/postgis/postgis_libprotobuf.c	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/postgis/postgis_libprotobuf.c	2019-08-14 22:07:40 UTC (rev 17711)
@@ -14,12 +14,12 @@
 PG_FUNCTION_INFO_V1(postgis_libprotobuf_version);
 Datum postgis_libprotobuf_version(PG_FUNCTION_ARGS)
-#ifndef HAVE_LIBPROTOBUF
-	PG_RETURN_NULL();
-#else /* HAVE_LIBPROTOBUF  */
+#ifdef HAVE_PROTOBUF_C_VERSION
 	const char *ver = protobuf_c_version();
 	text *result = cstring_to_text(ver);
 	PG_RETURN_POINTER(result);
+#else
+	PG_RETURN_NULL();
 #endif
@@ -33,4 +33,4 @@
 #endif
\ No newline at end of file
Modified: trunk/postgis_config.h.in
--- trunk/postgis_config.h.in	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/postgis_config.h.in	2019-08-14 22:07:40 UTC (rev 17711)
@@ -41,6 +41,12 @@
 /* Define to 1 if libprotobuf-c is present */
 #undef HAVE_LIBPROTOBUF
+/* Define to 1 if protobuf_c_version() is present */
+#undef HAVE_PROTOBUF_C_VERSION
+/* Numeric version number for libprotobuf */
+#undef LIBPROTOBUF_VERSION
 /* Define to 1 if libprotobuf-c is >= version 1.1 */
 #undef HAVE_GEOBUF
Modified: trunk/regress/core/Makefile.in
--- trunk/regress/core/Makefile.in	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/regress/core/Makefile.in	2019-08-14 22:07:40 UTC (rev 17711)
@@ -23,7 +23,7 @@
 POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
 HAVE_JSON=@HAVE_JSON@
 HAVE_PROTOBUF=@HAVE_PROTOBUF@
-PROTOCC_VERSION=@PROTOCC_VERSION@
+PROTOC_VERSION=@PROTOC_VERSION@
 HAVE_SPGIST=@HAVE_SPGIST@
 INTERRUPTTESTS=@INTERRUPTTESTS@
@@ -216,7 +216,7 @@
 	TESTS += \
 		mvt \
 		mvt_jsonb
-ifeq ($(shell expr $(PROTOCC_VERSION) ">=" 10100),1)
 	TESTS += \
 		geobuf
 endif
Modified: trunk/regress/core/geobuf.sql
--- trunk/regress/core/geobuf.sql	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/regress/core/geobuf.sql	2019-08-14 22:07:40 UTC (rev 17711)
@@ -19,3 +19,12 @@
     FROM (SELECT ST_MakePoint(1, 2, 3) as geom) AS q;
 SELECT 'T10', encode(ST_AsGeobuf(q), 'base64')
+WITH geom AS (
+	SELECT 'TRIANGLE((0 0, 1 1, 0 1, 0 0))'::geometry geom
+	union all
+	SELECT 'TIN(((0 0, 1 1, 0 1, 0 0)))'::geometry geom
+	union all
+	SELECT 'TRIANGLE EMPTY'::geometry geom
+select '#4399', 'ST_AsGeobuf', ST_AsGeobuf(geom.*)::text from geom;
Modified: trunk/regress/core/geobuf_expected
--- trunk/regress/core/geobuf_expected	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/regress/core/geobuf_expected	2019-08-14 22:07:40 UTC (rev 17711)
@@ -10,3 +10,4 @@
 T8|GAAiGAoWChQIBiIGCAAaAggMIggIAhoECAwGCA==
 T9|EAMYACILCgkKBwgAGgMCBAY=
 T10|EAMYACILCgkKBwgAGgMCBAY=
+#4399|ST_AsGeobuf|\x180022260a0c0a0a08041a060000020201000a100a0e0806220a08041a060000020201000a040a020804
Modified: trunk/regress/core/mvt.sql
--- trunk/regress/core/mvt.sql	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/regress/core/mvt.sql	2019-08-14 22:07:40 UTC (rev 17711)
@@ -733,6 +733,4 @@
 	union all
-select '#4399', 'ST_AsGeobuf', ST_AsGeobuf(geom.*)::text from geom
-union all
 select '#4399', 'ST_AsMVTGeom', ST_AsMVTGeom(geom, ST_MakeBox2D(ST_Point(0, 0), ST_Point(32, 32)))::text from geom;
Modified: trunk/regress/core/mvt_expected
--- trunk/regress/core/mvt_expected	2019-08-14 11:06:20 UTC (rev 17710)
+++ trunk/regress/core/mvt_expected	2019-08-14 22:07:40 UTC (rev 17711)
@@ -142,7 +142,6 @@
 #4348Reversed2|t
 #4348Point|t
 #4348Crash|t
-#4399|ST_AsGeobuf|\x180022260a0c0a0a08041a060000020201000a100a0e0806220a08041a060000020201000a040a020804
 #4399|ST_AsMVTGeom|011100000001000000040000000000000000000000000000000000B0400000000000000000000000000000AF400000000000006040000000000000AF400000000000000000000000000000B040
 #4399|ST_AsMVTGeom|
