[postgis-tickets] r17712 - Improve libprotobuf detection for old systems
Paul Ramsey
pramsey at cleverelephant.ca
Wed Aug 14 03:13:55 PDT 2019
Author: pramsey
Date: 2019-08-14 15:13:55 -0700 (Wed, 14 Aug 2019)
New Revision: 17712
branches/2.5/NEWS
branches/2.5/configure.ac
branches/2.5/postgis/Makefile.in
branches/2.5/postgis/postgis_libprotobuf.c
branches/2.5/postgis_config.h.in
branches/2.5/regress/Makefile.in
References #4481
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2019-08-14 22:07:40 UTC (rev 17711)
+++ branches/2.5/NEWS 2019-08-14 22:13:55 UTC (rev 17712)
@@ -21,6 +21,7 @@
- #4470, ST_GeomFromGeoJSON crash on empty rings (Darafei Praliaskouski)
- #4420, update path does not exists for address_standardizer extension (Regina Obe)
- #4480, Geography Distance inconsistent with Intersects (Paul Ramsey)
+ - #4481, Improve libprotobuf detection for old systems (Paul Ramsey)
PostGIS 2.5.2
Modified: branches/2.5/configure.ac
--- branches/2.5/configure.ac 2019-08-14 22:07:40 UTC (rev 17711)
+++ branches/2.5/configure.ac 2019-08-14 22:13:55 UTC (rev 17712)
@@ -939,7 +939,7 @@
dnl ===========================================================================
CHECK_PROTOBUF=yes
-HAVE_PROTOBUF=no
+HAVE_PROTOBUF=yes
AC_ARG_WITH([protobuf],
[AS_HELP_STRING([--without-protobuf], [build without protobuf-c support])],
@@ -948,86 +948,84 @@
dnl User didn't turn off protobuf support so...
if test "$CHECK_PROTOBUF" != "no"; then
- AC_ARG_WITH([protobufdir],
- [AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],
- [PROTOBUFDIR="$withval"], [PROTOBUFDIR=])
+ dnl Need to find libdir, incdir and protoc-c compiler
- dnl User specified the directory to find protobuf in, check that and
- dnl fail if it doesn't work
- if test ! "x$PROTOBUFDIR" = "x"; then
- dnl Make sure that the directory exists
- if test "x$PROTOBUFDIR" = "xyes"; then
- AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/path/to])
- else
- AC_MSG_RESULT([Using user-specified protobuf-c directory: $PROTOBUFDIR])
+ CPPFLAGS_SAVE="$CPPFLAGS"
+ LDFLAGS_SAVE="$LDFLAGS"
- dnl Add the include directory to PROTOBUF_CPPFLAGS
- PROTOBUF_CPPFLAGS="-I$PROTOBUFDIR/include"
- PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib"
- fi
+ dnl Try pkgconfig first
+ if test -n "$PKG_CONFIG"; then
+ dnl Ensure libprotobuf-c is of minimum required version
+ PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.0.0], [
+ PROTOBUF_CPPFLAGS="$PROTOBUFC_CFLAGS";
+ PROTOBUF_LDFLAGS="$PROTOBUFC_LIBS";
+ AC_MSG_RESULT([libprotobuf-c not found in pkg-config])
+ fi
- dnl Check that we can find the protobuf/protobuf.h header file
- CPPFLAGS_SAVE="$CPPFLAGS"
- CPPFLAGS="$PROTOBUF_CPPFLAGS"
- AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
- AC_MSG_ERROR([unable to find $PROTOBUFDIR/include/protobuf-c/protobuf-c.h])
- CPPFLAGS="$CPPFLAGS_SAVE"
+ AC_ARG_WITH([protobufdir],
+ [AS_HELP_STRING([--with-protobufdir=PATH], [specify the protobuf-c installation directory])],[
+ if test "x$withval" = "xyes"; then
+ AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/usr/local])
+ else
+ PROTOBUF_LDFLAGS="-L$withval/lib -lprotobuf-c";
+ PROTOBUF_CPPFLAGS="-I$withval/include"
+ fi
- dnl Ensure we can link against libprotobuf-c
- LIBS_SAVE="$LIBS"
- LIBS="$PROTOBUF_LDFLAGS"
- AC_CHECK_LIB([protobuf-c], [protobuf_c_message_check], [],
- AC_MSG_ERROR([unable to link protobuf-c from $PROTOBUFDIR/lib])
- HAVE_PROTOBUF=yes
- PROTOBUF_LDFLAGS="-L$PROTOBUFDIR/lib -lprotobuf-c"
- LIBS="$LIBS_SAVE"
+ if test -n "$PROTOBUF_CPPFLAGS"; then
+ CPPFLAGS="$PROTOBUF_CPPFLAGS"
+ fi
- dnl No user-specified protobuf dir, try to find one using pkg-config
- else
- if test -z "$PKG_CONFIG"; then
- AC_MSG_WARN([Cannot find pkg-config, disabling protobuf support.])
- HAVE_PROTOBUF=no
- else
- dnl Ensure libprotobuf-c is of minimum required version
- PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c], [
- HAVE_PROTOBUF=yes;
- PROTOBUF_CPPFLAGS=$PROTOBUFC_CFLAGS;
- PROTOBUF_LDFLAGS=$PROTOBUFC_LIBS
- [HAVE_PROTOBUF=no])
- fi
- fi
+ if test -n "$PROTOBUF_LDFLAGS"; then
+ LDFLAGS="$PROTOBUF_LDFLAGS"
+ fi
- if test "$HAVE_PROTOBUF" = "yes"; then
- AC_PATH_PROG(PROTOCC, protoc-c)
- if test "x$PROTOCC" = "x"; then
- AC_MSG_WARN([Protobuf compiler not in path, disabling protobuf support.])
- HAVE_PROTOBUF=no
- else
- AC_DEFINE([HAVE_LIBPROTOBUF], [1], [Define to 1 if libprotobuf-c is present])
- fi
- fi
+ dnl confirm that discovered/configured include path works
+ AC_CHECK_HEADER([protobuf-c/protobuf-c.h], [],
+ AC_MSG_RESULT([unable to find protobuf-c/protobuf-c.h using $CPPFLAGS])
+ HAVE_PROTOBUF=no
- dnl Get version number for protoc-c
+ dnl confirm that discovered/configured library path works
+ AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init], [],
+ AC_MSG_RESULT([unable to link protobuf-c using $LDFLAGS])
+ HAVE_PROTOBUF=no
+ AC_CHECK_LIB([protobuf-c], [protobuf_c_version],
+ AC_DEFINE([HAVE_PROTOBUF_C_VERSION], [1], [Define to 1 if protobuf_c_version() is present]),
+ AC_MSG_CHECKING([protobuf-c version])
+ AC_PROTOBUFC_VERSION([PROTOC_VERSION])
+ AC_MSG_RESULT([$PROTOC_VERSION])
+ CPPFLAGS="$CPPFLAGS_SAVE"
+ LDFLAGS="$LDFLAGS_SAVE"
+ dnl confirm that protobuf compiler is available
+ AC_PATH_PROG(PROTOCC, protoc-c)
+ if test -z "$PROTOCC"; then
+ AC_MSG_RESULT([Cannot find protoc-c protobuf compiler on the PATH: $PATH])
+ HAVE_PROTOBUF=no
+ fi
+ dnl all tests passed! turn on compile-time defines
- PROTOCC_SEMVER=$($PROTOCC --version | grep protobuf-c | awk '{print $2}')
- AC_MSG_RESULT([checking protoc-c version... $PROTOCC_SEMVER])
- PROTOCC_VERSION_MAJOR=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $1}')
- PROTOCC_VERSION_MINOR=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $2}')
- PROTOCC_VERSION_PATCH=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $3}')
- PROTOCC_VERSION=$(expr 10000 \* $PROTOCC_VERSION_MAJOR + 100 \* $PROTOCC_VERSION_MINOR + $PROTOCC_VERSION_PATCH)
- if test $PROTOCC_VERSION -ge 10100; then
- AC_DEFINE([HAVE_GEOBUF], [1], [Define to 1 if libprotobuf-c is >= 1.1])
- fi
- fi
+ AC_DEFINE([HAVE_LIBPROTOBUF], [1], [Define to 1 if libprotobuf-c is present])
+ AC_DEFINE_UNQUOTED([LIBPROTOBUF_VERSION], [$PROTOC_VERSION], [Numeric version number for libprotobuf-c])
+ if test $PROTOC_VERSION -ge 1001000; then
+ AC_DEFINE([HAVE_GEOBUF], [1], [Define to 1 if libprotobuf is >= 1.1])
+ fi
+ fi
- AC_SUBST([PROTOCC_VERSION])
+ AC_SUBST([HAVE_PROTOBUF])
+ AC_SUBST([PROTOC_VERSION])
AC_SUBST([PROTOBUF_CPPFLAGS])
AC_SUBST([PROTOBUF_LDFLAGS])
- AC_SUBST([HAVE_PROTOBUF])
fi
@@ -1524,7 +1522,7 @@
AC_MSG_RESULT([ protobuf-c support: ${HAVE_PROTOBUF}])
if test "x$HAVE_PROTOBUF" = "xyes"; then
- AC_MSG_RESULT([ protobuf-c version: ${PROTOCC_SEMVER}])
+ AC_MSG_RESULT([ protobuf-c version: ${PROTOC_VERSION}])
fi
AC_MSG_RESULT([ PCRE support: ${HAVE_PCRE}])
Modified: branches/2.5/postgis/Makefile.in
--- branches/2.5/postgis/Makefile.in 2019-08-14 22:07:40 UTC (rev 17711)
+++ branches/2.5/postgis/Makefile.in 2019-08-14 22:13:55 UTC (rev 17712)
@@ -56,7 +56,7 @@
ifeq (@HAVE_PROTOBUF@,yes)
PROTOBUF_OBJ = vector_tile.pb-c.o
-ifeq ($(shell expr @PROTOCC_VERSION@ ">=" 10100),1)
+ifeq ($(shell expr @PROTOC_VERSION@ ">=" 1001000),1)
PROTOBUF_OBJ += geobuf.pb-c.o
endif
endif
@@ -206,7 +206,7 @@
lwgeom_out_mvt.o: vector_tile.pb-c.h
-ifeq ($(shell expr $(PROTOCC_VERSION) ">=" 10100),1)
+ifeq ($(shell expr $(PROTOC_VERSION) ">=" 1001000),1)
lwgeom_out_geobuf.o: geobuf.pb-c.h
endif
Modified: branches/2.5/postgis/postgis_libprotobuf.c
--- branches/2.5/postgis/postgis_libprotobuf.c 2019-08-14 22:07:40 UTC (rev 17711)
+++ branches/2.5/postgis/postgis_libprotobuf.c 2019-08-14 22:13:55 UTC (rev 17712)
@@ -10,11 +10,11 @@
PG_FUNCTION_INFO_V1(postgis_libprotobuf_version);
Datum postgis_libprotobuf_version(PG_FUNCTION_ARGS)
-#ifndef HAVE_LIBPROTOBUF
+#ifndef HAVE_PROTOBUF_C_VERSION
PG_RETURN_NULL();
-#else /* HAVE_LIBPROTOBUF */
+#else /* HAVE_PROTOBUF_C_VERSION */
const char *ver = protobuf_c_version();
text *result = cstring_to_text(ver);
PG_RETURN_POINTER(result);
#endif
\ No newline at end of file
Modified: branches/2.5/postgis_config.h.in
--- branches/2.5/postgis_config.h.in 2019-08-14 22:07:40 UTC (rev 17711)
+++ branches/2.5/postgis_config.h.in 2019-08-14 22:13:55 UTC (rev 17712)
@@ -61,6 +61,12 @@
/* Define to 1 if libprotobuf-c is present */
#undef HAVE_LIBPROTOBUF
+/* Define to 1 if protobuf_c_version() is present */
+#undef HAVE_PROTOBUF_C_VERSION
+/* Numeric version number for libprotobuf */
+#undef LIBPROTOBUF_VERSION
/* Define to 1 if libprotobuf-c is >= version 1.1 */
#undef HAVE_GEOBUF
Modified: branches/2.5/regress/Makefile.in
--- branches/2.5/regress/Makefile.in 2019-08-14 22:07:40 UTC (rev 17711)
+++ branches/2.5/regress/Makefile.in 2019-08-14 22:13:55 UTC (rev 17712)
@@ -23,7 +23,7 @@
POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
HAVE_JSON=@HAVE_JSON@
HAVE_PROTOBUF=@HAVE_PROTOBUF@
-PROTOCC_VERSION=@PROTOCC_VERSION@
+PROTOC_VERSION=@PROTOC_VERSION@
HAVE_SFCGAL=@HAVE_SFCGAL@
HAVE_BRIN=@HAVE_BRIN@
HAVE_SPGIST=@HAVE_SPGIST@
@@ -252,7 +252,7 @@
# ST_AsMVT, ST_AsGeobuf
TESTS += \
mvt
TESTS += \
geobuf
endif
