[postgis-tickets] [PostGIS] #4485: regrssion test to test postgis_extensions_upgrade
PostGIS trac at osgeo.org
Tue Aug 20 04:38:07 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  task                   |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.5.4
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17736" 17736]:
 #!CommitTicketReference repository="" revision="17736"
 Add test for postgis_full_version()
 Closes #4485
 NOTE: the test is only included in the core tests, might need to
       be replicated for sfcgal/topology/raster
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4485#comment:4>
