[postgis-tickets] [PostGIS] #4485: regrssion test to test postgis_extensions_upgrade
PostGIS trac at osgeo.org
Tue Aug 20 05:17:51 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  task                   |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.5.4
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 I'm reopening because I didn't actually add any call to {{{
 postgis_extensions_upgrade() }}} with my commit. That's still all to do.
 What run_test.pl does at the moment is directly call {{{ ALTER EXTENSION
 ... UPDATE }}} when called with {{{ --extension }}} and {{{ --upgrade-path
 }}}. What we would want is something to have it perform the upgrade using
 the {{{ postgis_extensions_upgrade() }}} instead. What would a good switch
 name for that feature be ? Maybe {{{ --upgrade-with-function }}} ? Note
 that {{{ postgis_extensions_upgrade() }}} does not support a target
 version, so cannot always honour a user-provided {{{ --upgrade-path }}}.
 Also, it is not always available, and when is available we end up running
 the _old_ version of it, not the new version.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4485#comment:5>
