[postgis-tickets] [PostGIS] #4485: regrssion test to test postgis_extensions_upgrade
PostGIS trac at osgeo.org
Tue Aug 20 08:17:15 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  task                   |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.5.4
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 In [changeset:"17738" 17738]:
 #!CommitTicketReference repository="" revision="17738"
 Add support for :auto and :auto! upgrade-path targets in run_test.pl
 The former will request upgrading to default version, the latter
 to do so using the postgis_extension_upgrade() function.
 See #4485
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4485#comment:6>
