[postgis-tickets] r17739 - [check_all_upgrades] support :auto and :auto! upgrade targets
Sandro Santilli
strk at kbt.io
Tue Aug 20 08:17:36 PDT 2019
Author: strk
Date: 2019-08-20 08:17:36 -0700 (Tue, 20 Aug 2019)
New Revision: 17739
trunk/utils/check_all_upgrades.sh
See #4485
Modified: trunk/utils/check_all_upgrades.sh
--- trunk/utils/check_all_upgrades.sh 2019-08-20 15:17:14 UTC (rev 17738)
+++ trunk/utils/check_all_upgrades.sh 2019-08-20 15:17:36 UTC (rev 17739)
@@ -14,7 +14,11 @@
exit 1
fi
-to_version="$1"
+to_version_param="$1"
+to_version=$to_version_param
+if expr $to_version : ':auto' >/dev/null; then
+ to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"`
+fi
# Return -1, 1 or 0 if the first version
@@ -87,14 +91,15 @@
files=`'ls' ${EXT}--* | grep -v -- '--.*--' | sed "s/^${EXT}--\(.*\)\.sql/\1/"`
for fname in $files; do
from_version="$fname"
- UPGRADE_PATH="${from_version}--${to_version}"
+ UPGRADE_PATH="${from_version}--${to_version_param}"
+ UPGRADE_FILE="${EXT}--${from_version}--${to_version}.sql"
# only consider versions older than ${to_version}
cmp=`semver_compare "${from_version}" "${to_version}"`
if test $cmp -ge 0; then
- echo "SKIP: upgrade $UPGRADE_PATH (target is not newer than source)"
+ echo "SKIP: upgrade $UPGRADE_PATH ($to_version is not newer than $from_version)"
continue
fi
- if test -e ${EXT}--${UPGRADE_PATH}.sql; then
+ if test -e ${UPGRADE_FILE}; then
echo "Testing ${EXT} upgrade $UPGRADE_PATH"
export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
make -C ${REGDIR} check && {
@@ -104,13 +109,13 @@
failed
else
- echo "SKIP: ${EXT} upgrade $UPGRADE_PATH is missing"
+ echo "SKIP: ${EXT} upgrade $UPGRADE_FILE is missing"
fi
done
# Check unpackaged->extension upgrades
for majmin in "" `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
- UPGRADE_PATH="unpackaged${majmin}--${to_version}"
+ UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
