[postgis-tickets] r17740 - Change run-time endianness checks to	compile-time
    Paul Ramsey
    pramsey at cleverelephant.ca
    Tue Aug 20 09:01:52 PDT 2019
Author: pramsey
Date: 2019-08-20 09:01:52 -0700 (Tue, 20 Aug 2019)
New Revision: 17740
   trunk/loader/pgsql2shp-core.c
   trunk/loader/pgsql2shp-core.h
   trunk/raster/rt_core/rt_serialize.c
Leave 3rd party code unchanged
Closes #4439
Modified: trunk/loader/pgsql2shp-core.c
--- trunk/loader/pgsql2shp-core.c	2019-08-20 15:17:36 UTC (rev 17739)
+++ trunk/loader/pgsql2shp-core.c	2019-08-20 16:01:52 UTC (rev 17740)
@@ -45,7 +45,6 @@
 /* Prototypes */
 static int reverse_points(int num_points, double *x, double *y, double *z, double *m);
 static int is_clockwise(int num_points,double *x,double *y,double *z);
-static int is_bigendian(void);
 static SHPObject *create_point(SHPDUMPERSTATE *state, LWPOINT *lwpoint);
 static SHPObject *create_multipoint(SHPDUMPERSTATE *state, LWMPOINT *lwmultipoint);
 static SHPObject *create_polygon(SHPDUMPERSTATE *state, LWPOLY *lwpolygon);
@@ -577,21 +576,6 @@
 	return size;
-static int
-is_bigendian(void)
-	int test = 1;
-	if ( (((char *)(&test))[0]) == 1)
-		return 0; /*NDR (little_endian) */
-	else
-		return 1; /*XDR (big_endian) */
 char *
 shapetypename(int num)
@@ -1186,7 +1170,6 @@
 	state->dbffieldnames = NULL;
 	state->dbffieldtypes = NULL;
 	state->pgfieldnames = NULL;
-	state->big_endian = is_bigendian();
 	state->message[0] = '\0';
 	colmap_init(&state->column_map);
@@ -1890,30 +1873,27 @@
 		if (state->fieldcount > 0)
 			strcat(state->main_scan_query, ",");
-		if (state->big_endian)
+#ifdef WORDS_BIGENDIAN
+		if (state->pgis_major_version > 0)
-			if (state->pgis_major_version > 0)
-				sprintf(buf, "ST_asEWKB(ST_SetSRID(%s::geometry, 0), 'XDR') AS _geoX", quote_identifier(state->geo_col_name) );
-			else
-				sprintf(buf, "asbinary(%s::geometry, 'XDR') AS _geoX",
-					quote_identifier(state->geo_col_name) );
+			sprintf(buf, "ST_asEWKB(ST_SetSRID(%s::geometry, 0), 'XDR') AS _geoX", quote_identifier(state->geo_col_name) );
-		else /* little_endian */
+		else
-				sprintf(buf, "ST_AsEWKB(ST_SetSRID(%s::geometry, 0), 'NDR') AS _geoX", quote_identifier(state->geo_col_name) ) ;
-			else
-				sprintf(buf, "asbinary(%s::geometry, 'NDR') AS _geoX",
+			sprintf(buf, "asbinary(%s::geometry, 'XDR') AS _geoX",
+				quote_identifier(state->geo_col_name) );
+#else
+			sprintf(buf, "ST_AsEWKB(ST_SetSRID(%s::geometry, 0), 'NDR') AS _geoX", quote_identifier(state->geo_col_name) ) ;
+		else
+			sprintf(buf, "asbinary(%s::geometry, 'NDR') AS _geoX",
+#endif
 		strcat(state->main_scan_query, buf);
Modified: trunk/loader/pgsql2shp-core.h
--- trunk/loader/pgsql2shp-core.h	2019-08-20 15:17:36 UTC (rev 17739)
+++ trunk/loader/pgsql2shp-core.h	2019-08-20 16:01:52 UTC (rev 17740)
@@ -106,9 +106,6 @@
 	/* Version of PostGIS being used */
 	int pgis_major_version;
-	/* 0=dumper running on little endian, 1=dumper running on big endian */
-	int big_endian;
 	/* OID for geometries */
 	int geom_oid;
Modified: trunk/raster/rt_core/rt_serialize.c
--- trunk/raster/rt_core/rt_serialize.c	2019-08-20 15:17:36 UTC (rev 17739)
+++ trunk/raster/rt_core/rt_serialize.c	2019-08-20 16:01:52 UTC (rev 17740)
@@ -728,7 +728,11 @@
 	const uint8_t *beg = NULL;
 	uint16_t i = 0;
 	uint16_t j = 0;
-	uint8_t littleEndian = isMachineLittleEndian();
+	uint8_t littleEndian = LW_FALSE;
+#else
+	uint8_t littleEndian = LW_TRUE;
+#endif
 	assert(NULL != serialized);
