[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
trac at osgeo.org
Thu Aug 22 05:13:43 PDT 2019
Reporter: strk | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.1
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords: extension
Comment (by strk):
In [changeset:"17757" 17757]:
#!CommitTicketReference repository="" revision="17757"
Have postgis_extensions_upgrade repackage topology as well
Closes #4486
References #2503
See failure here:
https://gitlab.com/postgis/postgis/-/jobs/277847404
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:30>
