[postgis-tickets] [PostGIS] #4487: Split "check" rule in "check-unit" and "check-psql"
trac at osgeo.org
Thu Aug 22 05:16:38 PDT 2019
Reporter: strk | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
So that "installcheck" can avoid re-checking the unit test (since the unit
test will always use the pre-installed code anyway)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4487>
