[postgis-tickets] [PostGIS] #4182: Unexpected TopologyException during ST_Union aggregate function with valid polygons
trac at osgeo.org
Thu Aug 22 05:49:19 PDT 2019
polygons
Reporter: blaggner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by fengel):
I have similar TopologyExceptions on valid geometries quite often and I am
looking forward to the approvements that are on the way in JTS and GEOS.
In my experience large polygon tables in the real world (data from
institutions, geo portals etc.) are very often subject to this kind of
problem. Since the exception results in aborting the process it can become
quite problematic if you have to come up with a solution.
I was wondering if there are any recommendations for workarounds to this
issue. I currently use the functions st_safe_difference and
st_safe_intersection from this extension at the moment:
https://pgxn.org/dist/lostgis/1.0.2/ plus a self created safe_union
function. The main mechanism is exception handling which allows you to
ignore exceptions that cannot be solved. Using these functions I was able
to work with any kind of data so far and I didn't notice any major
drawbacks. But I am not sure if these solutions are reasonable and it
would be very interesting to see workaround strategies from other people.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4182#comment:8>
