[postgis-tickets] [PostGIS] #4182: Unexpected TopologyException during ST_Union aggregate function with valid polygons
trac at osgeo.org
Thu Aug 22 08:40:42 PDT 2019
polygons
Reporter: blaggner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by mdavis):
Of course one way to deal with the "tiny holes" is to simply remove holes
of less than a given area. However, it can happen (although not
necessarily in your dataset) that the spurious holes are actually long
slivers, which can have significant area but a very small cross-section.
A while ago I did some work on code to identify this sort of geometry, and
it worked pretty well. (One way is to buffer the sliver ring with a small
negative distance and see if it disappears)
There is also the potential for gores (inward thin spikes). These require
a different approach to deal with.
Which brings us to the question about whether the explicit precision model
in the new overlay code can help with this. Unfortunately, the answer is
"not entirely". Many times it does cause slivers to collapse away. But
there can be cases where the sliver is actually widened by the grid
snapping, in which case of course it still shows up as a hole.
The technical reason for this is that the snap-rounding is space-driven,
rather than data-driven. So if two nearby vertices happen to lie in
adjacent grid cells rather than the same one, they are snapped apart
rather than together.
(It would be a very interesting project to try and implement a data-driven
snapping facility. This would be relatively easy to do up to the 95%
level, but getting to 100% in a safe way is a challenge. Other systems
such as Arc do provide something like this, so it is possible...)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4182#comment:9>
