[postgis-tickets] [SCM] PostGIS branch master updated. bbbd77d0b9504281ad19731316ae7dd0ad7d9f6f
git at osgeo.org
git at osgeo.org
Thu Dec 12 06:57:53 PST 2019
the project "PostGIS".
via bbbd77d0b9504281ad19731316ae7dd0ad7d9f6f (commit)
from 21451108484d163e0b535bdfc5dcc7c07a0c853e (commit)
revisions in full, below.
commit bbbd77d0b9504281ad19731316ae7dd0ad7d9f6f
Author: Raúl Marín <git at rmr.ninja>
Date: Wed Dec 11 19:47:48 2019 +0100
LWGEOM_addpoint: Accept -1 as a valid position
Closes #4599
Closes https://github.com/postgis/postgis/pull/521
diff --git a/NEWS b/NEWS
index dea80ab..10130b7 100644
--- a/NEWS
+++ b/NEWS
@@ -33,7 +33,7 @@ PostGIS 3.1.0
- #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
- #4590, Fix pg_upgrade issue with st_linecrossingdirection (Raúl Marín)
- #4592, Add missing CPPFLAGS in multiple Makefiles (Raúl Marín)
+ - #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
PostGIS 3.0.0
2019/10/xx
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 89a395b..1a02b0a 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2204,7 +2204,7 @@ Datum LWGEOM_addpoint(PG_FUNCTION_ARGS)
GSERIALIZED *pglwg1, *pglwg2, *result;
LWPOINT *point;
LWLINE *line, *linecopy;
- int32 where = -1;
+ uint32_t uwhere = 0;
POSTGIS_DEBUGF(2, "%s called.", __func__);
@@ -2225,26 +2225,29 @@ Datum LWGEOM_addpoint(PG_FUNCTION_ARGS)
line = lwgeom_as_lwline(lwgeom_from_gserialized(pglwg1));
- if (PG_NARGS() > 2)
+ if (PG_NARGS() <= 2)
- where = PG_GETARG_INT32(2);
+ uwhere = line->points->npoints;
else
- where = line->points->npoints;
- if (where < 0 || where > (int32)line->points->npoints)
- elog(ERROR, "Invalid offset");
- PG_RETURN_NULL();
+ int32 where = PG_GETARG_INT32(2);
+ if (where == -1)
+ else if (where < 0 || where > (int32)line->points->npoints)
+ elog(ERROR, "Invalid offset");
+ PG_RETURN_NULL();
point = lwgeom_as_lwpoint(lwgeom_from_gserialized(pglwg2));
linecopy = lwgeom_as_lwline(lwgeom_clone_deep(lwline_as_lwgeom(line)));
lwline_free(line);
- if (lwline_add_lwpoint(linecopy, point, (uint32_t)where) == LW_FAILURE)
+ if (lwline_add_lwpoint(linecopy, point, uwhere) == LW_FAILURE)
elog(ERROR, "Point insert failed");
PG_RETURN_NULL();
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index adb64fb..4e1b3e0 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1284,3 +1284,7 @@ union all
select '#4399', 'ST_GeoHash', ST_GeoHash(geom)::text from geom
union all
select '#4399', 'ST_AsGeoJSON', ST_AsGeoJSON(geom)::text from geom;
+SELECT '#4599-1', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3)));
+SELECT '#4599-2', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3), 0));
+SELECT '#4599-3', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3), -1));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index e821f1c..4b34ba7 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -424,3 +424,6 @@ ERROR: BOX2D_construct: args can not be empty points
#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}
#4399|ST_AsGeoJSON|{"type":"GeometryCollection","geometries":[{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}]}
#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[]]}
+#4599-1|LINESTRING(0 0 1,1 1 1,1 2 3)
+#4599-2|LINESTRING(1 2 3,0 0 1,1 1 1)
+#4599-3|LINESTRING(0 0 1,1 1 1,1 2 3)
Summary of changes:
NEWS | 2 +-
postgis/lwgeom_functions_basic.c | 25 ++++++++++++++-----------
regress/core/tickets.sql | 4 ++++
regress/core/tickets_expected | 3 +++
4 files changed, 22 insertions(+), 12 deletions(-)
hooks/post-receive
