[postgis-tickets] [PostGIS] #4602: windows regress failing on ST_TileEnvelope
PostGIS trac at osgeo.org
Thu Dec 12 09:44:51 PST 2019
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:  windows
Changes (by Algunenano):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Seems to be fixed with the improved bbox precision:
 https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/10146/console
  quantize_coordinates .. ok in 299 ms
  regress .. ok in 613 ms
 But the build is failing because of issues that were there before:
 ../loader/Point ........ failed (dumper geog test: dumping loaded table:
 /projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.3w64/dumper.err)
 Initializing...
 Done (postgis major version: 3).
 Output shape: Point
 Dumping: XError in psSHP->sHooks.FWrite() while writing object of 28 bytes
 to .shp file: No error
 Error writing shape 0
 I'm closing this ticket and I'll open a new one for that issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4602#comment:3>
