[postgis-tickets] [PostGIS] #4447: sfcgal tests failing
trac at osgeo.org
Tue Jul 2 20:23:44 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.5.x
Keywords: |
This started happening on both winnie and debbie today as a result of
r17579
seems to be just 2.5 branch. trunk is fine
Commit 34cb1b2c11e06e901a9c29b854aea9a7e197c704 by rmrodriguez
Fix bug in lwgeom_le
References #4445
git-svn-id: http://svn.osgeo.org/postgis/branches/2.5@17579
b70326c6-7e19-0410-871a-916f4a2858ee
sfcgal/tickets .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_5_pg10w64/test_136_diff)
--- sfcgal/tickets_expected 2019-06-28 17:30:18.282838964 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg10w64/test_136_out
2019-07-02 09:26:58.691382154 +0000
@@ -95,7 +95,7 @@
#835.11|MULTILINESTRING EMPTY
#835.12|MULTIPOLYGON EMPTY
#650|MULTIPOINT(0 0,1 1,2 2)
-ERROR: function postgis_sfcgal_version() does not exist at character 118
+#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30
40))
#677|1121395
#680|01d107000000000000000024c000000000000049400000000000000040
#681a|
sfcgal/concave_hull .. ok
sfcgal/wmsservers .. ok
sfcgal/approximatemedialaxis .. ok
uninstall . /var/lib/jenkins/workspace/postgis/branches/2.5/regress/00
-regress-install/share/contrib/postgis/uninstall_sfcgal.sql
/var/lib/jenkins/workspace/postgis/branches/2.5/regress/00-regress-
install/share/contrib/postgis/uninstall_postgis.sql
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4447>
