[postgis-tickets] [PostGIS] #4447: sfcgal tests failing
trac at osgeo.org
Tue Jul 2 20:31:37 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> This started happening on both winnie and debbie today as a result of
> r17579
> seems to be just 2.5 branch. trunk is fine
> Commit 34cb1b2c11e06e901a9c29b854aea9a7e197c704 by rmrodriguez
> Fix bug in lwgeom_le
> References #4445
> git-svn-id: http://svn.osgeo.org/postgis/branches/2.5@17579
> b70326c6-7e19-0410-871a-916f4a2858ee
> sfcgal/tickets .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/2_5_pg10w64/test_136_diff)
> --- sfcgal/tickets_expected 2019-06-28 17:30:18.282838964 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg10w64/test_136_out
> 2019-07-02 09:26:58.691382154 +0000
> @@ -95,7 +95,7 @@
> #835.11|MULTILINESTRING EMPTY
> #835.12|MULTIPOLYGON EMPTY
> #650|MULTIPOINT(0 0,1 1,2 2)
> -ERROR: function postgis_sfcgal_version() does not exist at character
> 118
> +#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30
> 40))
> #677|1121395
> #680|01d107000000000000000024c000000000000049400000000000000040
> #681a|
> sfcgal/concave_hull .. ok
> sfcgal/wmsservers .. ok
> sfcgal/approximatemedialaxis .. ok
> uninstall . /var/lib/jenkins/workspace/postgis/branches/2.5/regress/00
> -regress-install/share/contrib/postgis/uninstall_sfcgal.sql
> /var/lib/jenkins/workspace/postgis/branches/2.5/regress/00-regress-
> install/share/contrib/postgis/uninstall_postgis.sql
New description:
r17558 or r17579
I can't tell which one is at fault since at r17558 bots were failing for
non-related code reason.
@@ -95,7 +95,7 @@
-ERROR: function postgis_sfcgal_version() does not exist at character 118
40))
#677|1121395
#681a|
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4447#comment:1>
