[postgis-tickets] [PostGIS] #4450: Speed up ST_GeometryType by avoiding strncat calls
trac at osgeo.org
Fri Jul 5 08:58:41 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
`ST_GeometryType` is currently doing 2 strncat calls which aren't
necessary since the output is always the same and can be stored
statically.
Performance difference:
Select ST_GeometryType(the_geom_webmercator) from
benchmark_7773a711c8441d4b494a51fd9feebeac7a9b9c734619398620293;
Before:
number of transactions actually processed: 407
latency average = 296.925 ms
tps = 13.471411 (including connections establishing)
tps = 13.474553 (excluding connections establishing)
Using a static char**:
number of transactions actually processed: 437
latency average = 275.895 ms
tps = 14.498272 (including connections establishing)
tps = 14.501781 (excluding connections establishing)
10% ain't much, but it's honest work
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4450>
