[postgis-tickets] r17585 - Fix the calculation of gserialized_max_header_size
Raul
raul at rmr.ninja
Tue Jul 9 08:33:24 PDT 2019
Author: algunenano
Date: 2019-07-09 08:33:24 -0700 (Tue, 09 Jul 2019)
New Revision: 17585
trunk/NEWS
trunk/liblwgeom/gserialized1.c
trunk/liblwgeom/gserialized2.c
Closes #4451
Closes https://github.com/postgis/postgis/pull/433
Modified: trunk/NEWS
--- trunk/NEWS 2019-07-09 15:30:01 UTC (rev 17584)
+++ trunk/NEWS 2019-07-09 15:33:24 UTC (rev 17585)
@@ -7,6 +7,7 @@
* Major highlights *
- #4433 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
- #4445, Fix a bug in geometry_le (Raúl Marín)
+ - #4451, Fix the calculation of gserialized_max_header_size (Raúl Marín)
PostGIS 3.0.0alpha3
Modified: trunk/liblwgeom/gserialized1.c
--- trunk/liblwgeom/gserialized1.c 2019-07-09 15:30:01 UTC (rev 17584)
+++ trunk/liblwgeom/gserialized1.c 2019-07-09 15:33:24 UTC (rev 17585)
@@ -113,8 +113,9 @@
uint32_t gserialized1_max_header_size(void)
- /* read GSERIALIZED size + max bbox according gbox_serialized_size (2 + Z + M) + 1 int for type */
- return sizeof(GSERIALIZED) + 8 * sizeof(float) + sizeof(int);
+ static const intptr_t size_of_gserialized_up_to_data = (intptr_t) & ((GSERIALIZED *)NULL)->data;
+ /* GSERIALIZED size + max bbox according gbox_serialized_size (XYZM*2) + extended flags + type */
+ return size_of_gserialized_up_to_data + 8 * sizeof(float) + sizeof(uint32_t);
static uint32_t gserialized1_header_size(const GSERIALIZED *gser)
Modified: trunk/liblwgeom/gserialized2.c
--- trunk/liblwgeom/gserialized2.c 2019-07-09 15:30:01 UTC (rev 17584)
+++ trunk/liblwgeom/gserialized2.c 2019-07-09 15:33:24 UTC (rev 17585)
@@ -161,8 +161,9 @@
uint32_t gserialized2_max_header_size(void)
- /* read GSERIALIZED size + max bbox according gbox_serialized_size (XYZM*2) + extended flags + 1 int for type */
- return sizeof(GSERIALIZED) + 8 * sizeof(float) + sizeof(uint64_t) + sizeof(int);
+ return size_of_gserialized_up_to_data + 8 * sizeof(float) + sizeof(uint64_t) + sizeof(uint32_t);
