[postgis-tickets] r17586 - Speed up ST_GeometryType
Raul
raul at rmr.ninja
Tue Jul 9 08:43:19 PDT 2019
Author: algunenano
Date: 2019-07-09 08:43:19 -0700 (Tue, 09 Jul 2019)
New Revision: 17586
trunk/NEWS
trunk/postgis/lwgeom_ogc.c
Closes https://github.com/postgis/postgis/pull/434
Closes #4450
Modified: trunk/NEWS
--- trunk/NEWS 2019-07-09 15:33:24 UTC (rev 17585)
+++ trunk/NEWS 2019-07-09 15:43:19 UTC (rev 17586)
@@ -8,6 +8,7 @@
- #4433 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
- #4445, Fix a bug in geometry_le (Raúl Marín)
- #4451, Fix the calculation of gserialized_max_header_size (Raúl Marín)
+ - #4450, Speed up ST_GeometryType (Raúl Marín)
PostGIS 3.0.0alpha3
Modified: trunk/postgis/lwgeom_ogc.c
--- trunk/postgis/lwgeom_ogc.c 2019-07-09 15:33:24 UTC (rev 17585)
+++ trunk/postgis/lwgeom_ogc.c 2019-07-09 15:43:19 UTC (rev 17586)
@@ -170,6 +170,23 @@
PG_RETURN_TEXT_P(text_ob);
+/* Matches lwutil.c::lwgeomTypeName */
+static char *stTypeName[] = {"Unknown",
+ "ST_Point",
+ "ST_LineString",
+ "ST_Polygon",
+ "ST_MultiPoint",
+ "ST_MultiLineString",
+ "ST_MultiPolygon",
+ "ST_GeometryCollection",
+ "ST_CircularString",
+ "ST_CompoundCurve",
+ "ST_CurvePolygon",
+ "ST_MultiCurve",
+ "ST_MultiSurface",
+ "ST_PolyhedralSurface",
+ "ST_Triangle",
+ "ST_Tin"};
/* returns a string representation of this geometry's type */
PG_FUNCTION_INFO_V1(geometry_geometrytype);
@@ -177,21 +194,12 @@
GSERIALIZED *gser;
text *type_text;
-# define type_str_len 31
- char type_str[type_str_len + 1];
/* Read just the header from the toasted tuple */
gser = PG_GETARG_GSERIALIZED_P_SLICE(0, 0, gserialized_max_header_size());
- /* Make it empty string to start */
- type_str[0] = 0;
- /* Build up the output string */
- strncat(type_str, "ST_", type_str_len);
- strncat(type_str, lwtype_name(gserialized_get_type(gser)), type_str_len - 3);
/* Build a text type to store things in */
- type_text = cstring_to_text(type_str);
+ type_text = cstring_to_text(stTypeName[gserialized_get_type(gser)]);
PG_FREE_IF_COPY(gser, 0);
PG_RETURN_TEXT_P(type_text);
