[postgis-tickets] [PostGIS] #4461: ST_AsTWKB doesn't always remove duplicate points
trac at osgeo.org
Sun Jul 21 00:43:12 PDT 2019
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
In this tweet gabrielroldan says that ST_AsTWKB doesn't remove repeated
points
https://twitter.com/gabrielroldan/status/1152379542801174528
and he is right for some cases. If the writer haven't yet collected enough
points for what is needed for that geometry type it doesn't remove the
point even if there is many more points after.
The function actually needs one extra before it starts removing.
Example
select st_astwkb('linestring(1 1, 2 2, 2 2, 3 1)'::geometry);
The fix is very small, but might be a braking change for someone.
The proposed svn diff:
svn diff
Index: liblwgeom/lwout_twkb.c
--- liblwgeom/lwout_twkb.c (revision 17618)
+++ liblwgeom/lwout_twkb.c (working copy)
@@ -112,7 +112,8 @@
int64_t nextdelta[MAX_N_DIMS];
int npoints = 0;
size_t npoints_offset = 0;
+ int max_points_left = pa->npoints;
LWDEBUGF(2, "Entered %s", __func__);
/* Dispense with the empty case right away */
@@ -173,8 +174,11 @@
/* Skipping the first point is not allowed */
/* If the sum(abs()) of all the deltas was zero, */
/* then this was a duplicate point, so we can ignore it */
- if ( i > minpoints && diff == 0 )
+ if ( diff == 0 && max_points_left > minpoints )
+ max_points_left--;
continue;
/* We really added a point, so... */
npoints++;
Index: liblwgeom/measures3d.c
--- liblwgeom/measures3d.c (revision 17618)
+++ liblwgeom/measures3d.c (working copy)
@@ -1508,7 +1508,6 @@
pl->pv.z += vp.z / vl;
return (!FP_IS_ZERO(pl->pv.x) || !FP_IS_ZERO(pl->pv.y) ||
!FP_IS_ZERO(pl->pv.z));
Any thoughts before I commit?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4461>
