[postgis-tickets] [PostGIS] #4464: PostGIS 2.5 not regressing cleanly in PostgreSQL 9.4
PostGIS trac at osgeo.org
Sat Jul 27 10:58:58 PDT 2019
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.5.3
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Debbie's 9.4 runs are failing on PostGIS 2.5.
> This seems to have started after r17528 (that's the last successful run)
> on Jun 13th.  It's hard to tell which commit after caused the issue since
> it caused other problems with other PostgreSQL versions that were cleaned
> up by later commits.
New description:
 failures are below
  ctors .. ok
  curvetoline .. ok
  dump .. ok
  dumppoints .. ok
  empty .. ok
  estimatedextent .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.4w64/test_41_diff)
 --- estimatedextent_expected    2019-06-28 17:30:18.282838964 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.4w64/test_41_out
 2019-07-27 17:30:56.923315007 +0000
 @@ -6,32 +6,17 @@
  WARNING:  stats for "t.g" do not exist
  #877.2.deprecated|
 -WARNING:  stats for "t.g" do not exist
  #877.3||||
  #877.4|-10.15000|20.15000|-50.40000|30.40000
  #877.5|-10.15000|20.15000|-50.40000|30.40000
  WARNING:  stats for "c1.g" do not exist
 -WARNING:  stats for "c1.g" do not exist
  #3391.1||||
  WARNING:  stats for "c2.g" do not exist
 -WARNING:  stats for "c2.g" do not exist
  #3391.2||||
  WARNING:  stats for "p.g" do not exist
 -WARNING:  stats for "p.g" do not exist
  #3391.3||||
  #3391.4|0.00|1.00|0.00|1.00
  #3391.5||||
  #3391.6|0.00|1.00|0.00|1.00
  #3391.7|0.00|1.00|0.00|1.00
 @@ -41,30 +26,15 @@
  #3391.11|-1.00|0.00|-1.00|0.00
  #3391.12|-1.01|2.02|-1.01|2.02
  #3391.13||||
  #3391.14||||
  #3391.15||||
  #3391.16||||
  #3391.17|0.00|1.00|0.00|1.00
  #3391.18||||
  #3391.19|0.00|1.00|0.00|1.00
  #3391.20|0.00|1.00|0.00|1.00
  forcecurve .. ok
  geography .. ok
  geometric_median .. ok
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  in_encodedpolyline .. ok
  iscollection .. ok
  legacy .. ok
  long_xact .. ok
  lwgeom_regress .. ok
  measures .. ok
  minimum_bounding_circle .. ok
  normalize .. ok
  operators .. ok
  orientation .. ok
  out_geometry .. ok
  out_geography .. ok
  polygonize .. ok
  polyhedralsurface .. ok
  postgis_type_name .. ok
  quantize_coordinates .. ok
  regress .. ok
  regress_bdpoly .. ok
  regress_gist_index_nd .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  regress_management .. ok
  regress_selectivity .. ok
  regress_lrs .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_proj .. ok
  relate .. ok
  remove_repeated_points .. ok
  removepoint .. ok
  reverse .. ok
  setpoint .. ok
  simplify .. ok
  simplifyvw .. ok
  size .. ok
  snaptogrid .. ok
  split .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  swapordinates .. ok
  summary .. ok
  temporal .. ok
  tickets .. ok
  twkb .. ok
  typmod .. ok
  wkb .. ok
  wkt .. ok
  wmsservers .. ok
  knn .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  clipbybox2d .. ok
  subdivide .. ok
  voronoi .. ok
  minimum_clearance .. ok
  oriented_envelope .. ok
  in_geojson .. ok
  mvt .. ok
  geobuf .. ok
  mvt_jsonb .. ok
  regress_sfcgal .. ok
  sfcgal/empty .. ok
  sfcgal/geography .. ok
  sfcgal/legacy .. ok
  sfcgal/measures .. ok
  sfcgal/regress_ogc_prep .. ok
  sfcgal/regress_ogc .. ok
  sfcgal/regress .. ok
  sfcgal/tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.4w64/test_132_diff)
 --- sfcgal/tickets_expected     2019-07-02 09:49:06.918850303 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.4w64/test_132_out
 2019-07-27 17:31:52.062722324 +0000
 @@ -151,9 +151,6 @@
  #877.2.deprecated|
  #877.3||||
  sfcgal/concave_hull .. ok
  sfcgal/wmsservers .. ok
  sfcgal/approximatemedialaxis .. ok
  uninstall .  /var/lib/jenkins/workspace/postgis/branches/2.5/regress/00
 -regress-install/share/contrib/postgis/uninstall_sfcgal.sql
   /var/lib/jenkins/workspace/postgis/branches/2.5/regress/00-regress-
 install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4336)
 Looks like might just be number of warnings output perhaps because of
 change of number of runs or something.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4464#comment:1>
