[postgis-tickets] r17621 - Support for srid reprojection when using	-D switch
    Regina Obe
    lr at pcorp.us
    Sun Jul 28 02:14:48 PDT 2019
Author: robe
Date: 2019-07-28 14:14:48 -0700 (Sun, 28 Jul 2019)
New Revision: 17621
   trunk/NEWS
   trunk/doc/using_postgis_dataman.xml
   trunk/loader/README.shp2pgsql
   trunk/loader/shp2pgsql-cli.c
   trunk/loader/shp2pgsql-core.c
   trunk/loader/shp2pgsql-core.h
References #4403
Tests forthcoming
Modified: trunk/NEWS
--- trunk/NEWS	2019-07-22 13:27:46 UTC (rev 17620)
+++ trunk/NEWS	2019-07-28 21:14:48 UTC (rev 17621)
@@ -16,6 +16,7 @@
   - #4454, Speed up _ST_OrderingEquals (Raúl Marín)
   - #4453, Speed up ST_IsEmpty (Raúl Marín)
   - #4271, postgis_extensions_upgrade() also updates after pg_upgrade (Raúl Marín)
+  - #4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
 PostGIS 3.0.0alpha3
 2019/07/01
Modified: trunk/doc/using_postgis_dataman.xml
--- trunk/doc/using_postgis_dataman.xml	2019-07-22 13:27:46 UTC (rev 17620)
+++ trunk/doc/using_postgis_dataman.xml	2019-07-28 21:14:48 UTC (rev 17621)
@@ -1672,7 +1672,6 @@
           Optionally specifies that the input shapefile uses the given
           FROM_SRID, in which case the geometries will be reprojected to the
           target SRID.
-	  FROM_SRID cannot be specified with -D.
         </para>
       </listitem>
     </varlistentry>
Modified: trunk/loader/README.shp2pgsql
--- trunk/loader/README.shp2pgsql	2019-07-22 13:27:46 UTC (rev 17620)
+++ trunk/loader/README.shp2pgsql	2019-07-28 21:14:48 UTC (rev 17621)
@@ -53,10 +53,13 @@
               the default "insert" SQL format. Use this for  very  large  data
               sets.
-       -s <SRID>
-              Creates  and  populates  the  geometry tables with the specified
-              SRID.
+       -s [<FROM_SRID>:]<SRID>
+              Creates and populates the geometry tables with the specified SRID.
+              Optionally specifies that the input shapefile uses the given
+              FROM_SRID, in which case the geometries will be reprojected
+              to the target SRID.
        -g <geometry_column>
               Specify the name of the geometry column (mostly useful in append
               mode).
@@ -113,8 +116,9 @@
 AUTHORS
-       Originally   written   by  Jeff  Lounsbury  <jeffloun at refractions.net>.
-       Improved and  maintained  by  Sandro  Santilli  <strk at kbt.io>.
+       Originally written by Jeff Lounsbury <jeffloun at refractions.net>.
+       Improved and maintained by
+       Sandro Santilli <strk at kbt.io>, Regina Obe <lr at pcorp.us>.
        Includes small contributions and improvements by others.
        This  application  uses  functionality  from  shapelib  1.2.9  by Frank
Modified: trunk/loader/shp2pgsql-cli.c
--- trunk/loader/shp2pgsql-cli.c	2019-07-22 13:27:46 UTC (rev 17620)
+++ trunk/loader/shp2pgsql-cli.c	2019-07-28 21:14:48 UTC (rev 17621)
@@ -24,7 +24,7 @@
 	printf(_( "USAGE: shp2pgsql [<options>] <shapefile> [[<schema>.]<table>]\n"
 	          "OPTIONS:\n" ));
 	printf(_( "  -s [<from>:]<srid> Set the SRID field. Defaults to %d.\n"
-	          "      Optionally reprojects from given SRID (cannot be used with -D).\n"),
+	          "      Optionally reprojects from given SRID.\n"),
 	          SRID_UNKNOWN);
 	printf(_( " (-d|a|c|p) These are mutually exclusive options:\n"
 	          "     -d  Drops the table, then recreates it and populates\n"
@@ -250,12 +250,6 @@
 		exit(1);
-	if (config->dump_format && config->shp_sr_id != SRID_UNKNOWN)
-		fprintf(stderr, "Invalid argument combination - cannot use -D with -s FROM_SRID:TO_SRID\n");
-		exit(1);
 	/* Determine the shapefile name from the next argument, if no shape file, exit. */
 	if (pgis_optind < argc)
Modified: trunk/loader/shp2pgsql-core.c
--- trunk/loader/shp2pgsql-core.c	2019-07-22 13:27:46 UTC (rev 17620)
+++ trunk/loader/shp2pgsql-core.c	2019-07-28 21:14:48 UTC (rev 17621)
@@ -786,6 +786,7 @@
 	state->widths = NULL;
 	state->precisions = NULL;
 	state->col_names = NULL;
+	state->col_names_no_paren = NULL;
 	state->field_names = NULL;
 	state->num_fields = 0;
 	state->pgfieldtypes = NULL;
@@ -1090,10 +1091,11 @@
 	state->precisions = malloc(state->num_fields * sizeof(int));
 	state->pgfieldtypes = malloc(state->num_fields * sizeof(char *));
 	state->col_names = malloc((state->num_fields + 2) * sizeof(char) * MAXFIELDNAMELEN);
+	state->col_names_no_paren = malloc((state->num_fields + 2) * sizeof(char) * MAXFIELDNAMELEN);
-	/* Generate a string of comma separated column names of the form "(col1, col2 ... colN)" for the SQL
+	strcpy(state->col_names_no_paren, "" );
+	/* Generate a string of comma separated column names of the form "col1, col2 ... colN" for the SQL
 	   insertion string */
-	strcpy(state->col_names, "(" );
 	for (j = 0; j < state->num_fields; j++)
@@ -1243,24 +1245,28 @@
 			return SHPLOADERERR;
-		strcat(state->col_names, "\"");
-		strcat(state->col_names, name);
+		strcat(state->col_names_no_paren, "\"");
+		strcat(state->col_names_no_paren, name);
 		if (state->config->readshape == 1 || j < (state->num_fields - 1))
 			/* Don't include last comma if its the last field and no geometry field will follow */
-			strcat(state->col_names, "\",");
+			strcat(state->col_names_no_paren, "\",");
 		else
 	/* Append the geometry column if required */
 	if (state->config->readshape == 1)
-		strcat(state->col_names, state->geo_col);
+		strcat(state->col_names_no_paren, state->geo_col);
+	/** Create with (col1,col2,..) ( **/
+	strcpy(state->col_names, "(" );
+	strcat(state->col_names, state->col_names_no_paren);
 	strcat(state->col_names, ")");
@@ -1455,6 +1461,23 @@
+	/**If we are in dump mode and a transform was asked for need to create a temp table to store original data
+	 You may ask, why don't we go straight into the main table and then do an alter table alter column afterwards
+	 Main reason is so we don't incur the penalty of WAL logging when we change the typmod in final run. **/
+	if (state->config->dump_format && state->to_srid != state->from_srid){
+		/** create a temp table with same structure as main except for no restriction on geometry type */
+		stringbuffer_aprintf(sb, "CREATE TEMP TABLE \"pgis_tmp_%s\" AS SELECT * FROM ", state->config->table);
+		/* Schema is optional, include if present. */
+		if (state->config->schema)
+			stringbuffer_aprintf(sb, "\"%s\".",state->config->schema);
+		stringbuffer_aprintf(sb, "\"%s\" WHERE false;\n", state->config->table, state->geo_col);
+		/**out input data is going to be in different srid from target, so need to remove type constraint **/
+		stringbuffer_aprintf(sb, "ALTER TABLE \"pgis_tmp_%s\" ALTER COLUMN \"%s\" TYPE geometry USING ( (\"%s\"::geometry) ); \n", state->config->table,  state->geo_col, state->geo_col);
 	/* Copy the string buffer into a new string, destroying the string buffer */
 	ret = (char *)malloc(strlen((char *)stringbuffer_getstring(sb)) + 1);
 	strcpy(ret, (char *)stringbuffer_getstring(sb));
@@ -1470,27 +1493,38 @@
 int
 ShpLoaderGetSQLCopyStatement(SHPLOADERSTATE *state, char **strheader)
-	char *copystr;
+	//char *copystr;
+	stringbuffer_t *sb;
+	char *ret;
+	sb = stringbuffer_create();
+	stringbuffer_clear(sb);
 	/* Allocate the string for the COPY statement */
 	if (state->config->dump_format)
-		if (state->config->schema)
-			copystr = malloc(strlen(state->config->schema) + strlen(state->config->table) +
-			                 strlen(state->col_names) + 40);
+		stringbuffer_aprintf(sb, "COPY ");
-			sprintf(copystr, "COPY \"%s\".\"%s\" %s FROM stdin;\n",
-			        state->config->schema, state->config->table, state->col_names);
+		if (state->to_srid != state->from_srid){
+			/** if we need to transform we copy into temp table instead of main table first */
+			stringbuffer_aprintf(sb, " \"pgis_tmp_%s\" %s FROM stdin;\n", state->config->table, state->col_names);
-		else
-			copystr = malloc(strlen(state->config->table) + strlen(state->col_names) + 40);
+		else {
+				stringbuffer_aprintf(sb, " \"%s\".\" ", state->config->schema);
-			sprintf(copystr, "COPY \"%s\" %s FROM stdin;\n", state->config->table, state->col_names);
+			stringbuffer_aprintf(sb, " \"%s\" %s FROM stdin;\n", state->config->table, state->col_names);
+		/* Copy the string buffer into a new string, destroying the string buffer */
+		ret = (char *)malloc(strlen((char *)stringbuffer_getstring(sb)) + 1);
+		strcpy(ret, (char *)stringbuffer_getstring(sb));
+		stringbuffer_destroy(sb);
-		*strheader = copystr;
+		*strheader = ret;
 		return SHPLOADEROK;
 	else
@@ -1836,6 +1870,26 @@
+	if ( state->config->dump_format && state->to_srid != state->from_srid){
+		/** We need to copy from the temp table to the real table, transforming to to_srid **/
+		stringbuffer_aprintf(sb, "ALTER TABLE  \"pgis_tmp_%s\" ALTER COLUMN \"%s\" TYPE ",   state->config->table, state->geo_col );
+		if (state->config->geography){
+			stringbuffer_aprintf(sb, "geography USING (ST_Transform(\"%s\", %d)::geography );\n", state->geo_col, state->to_srid);
+		else {
+			stringbuffer_aprintf(sb, "geometry USING (ST_Transform(\"%s\", %d)::geometry );\n", state->geo_col, state->to_srid);
+		stringbuffer_aprintf(sb, "INSERT INTO ");
+		// /* Schema is optional, include if present. */
+			stringbuffer_aprintf(sb, "\"%s\".", state->config->schema);
+		stringbuffer_aprintf(sb, "\"%s\" %s ", state->config->table, state->col_names);
+		stringbuffer_aprintf(sb, "SELECT %s FROM \"pgis_tmp_%s\";\n", state->col_names_no_paren, state->config->table );
 	/* Create gist index if specified and not in "prepare" mode */
 	if (state->config->readshape && state->config->createindex)
@@ -1913,6 +1967,9 @@
 		if (state->col_names)
 			free(state->col_names);
+		if (state->col_names_no_paren)
+			free(state->col_names_no_paren);
 		/* Free any column map fieldnames if specified */
 		colmap_clean(&state->column_map);
Modified: trunk/loader/shp2pgsql-core.h
--- trunk/loader/shp2pgsql-core.h	2019-07-22 13:27:46 UTC (rev 17620)
+++ trunk/loader/shp2pgsql-core.h	2019-07-28 21:14:48 UTC (rev 17621)
@@ -192,6 +192,9 @@
 	/* String containing colume name list in the form "(col1, col2, col3 ... , colN)" */
 	char *col_names;
+	/* String containing colume name list in the form "col1, col2, col3 ... , colN" */
+	char *col_names_no_paren;
 	/* String containing the PostGIS geometry type, e.g. POINT, POLYGON etc. */
 	char *pgtype;
