[postgis-tickets] [PostGIS] #4464: PostGIS 2.5 not regressing cleanly in PostgreSQL 9.4
trac at osgeo.org
Wed Jul 31 13:32:06 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by pramsey):
Yuh, I get the same effect, it looks like 9.4 has slightly different
behaviour from 9.5 in terms of how it executes things like
select '#877.3',
round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
round(st_ymin(e.e)::numeric, 5), round(st_ymax(e.e)::numeric, 5)
from ( select ST_EstimatedExtent('t','g') as e ) e;
9.4 manages to execute it, running `ST_EstimatedExtent` just once, while
9.5/9.6/10/11/12 run it four times (and gets four notices as a result).
I'm not sure what we do except excise those tests, we cannot unfortunately
use the MATERIALIZE keyword in the older versions to force 12 to have the
same behaviour as the older ones.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4464#comment:3>
