[postgis-tickets] [PostGIS] #4462: st_asmvtgeom fails with IllegalArgumentException: RobustDeterminant encountered non-finite numbers
PostGIS trac at osgeo.org
Sun Jul 28 18:18:37 PDT 2019
  Reporter:  autra    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.3
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by robe):
 autra -- I just noticed your output says 3.7.2dev (and not 3.7.2) so you
 are running with a pre-released version of geos 3.7.2 it seems which might
 not have needed fixes.  Try redownloading GEOS (make sure you are working
 from released 3.7.2 - http://download.osgeo.org/geos/geos-3.7.2.tar.bz2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4462#comment:7>
