[postgis-tickets] [PostGIS] #4462: st_asmvtgeom fails with IllegalArgumentException: RobustDeterminant encountered non-finite numbers
PostGIS trac at osgeo.org
Mon Jul 29 01:50:09 PDT 2019
  Reporter:  autra    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.3
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by autra):
 @robe thank you. Meanwhile I tested on a debian buster, and my problem was
 fixed (so with geos 3.7.1 and postgis 2.5). Is it only possible that the
 fix is in 3.7.1, 3.7.2 without being in 3.7.2-dev? I don't know your
 branch workflow, so you will know better than I do :-)
 Also, I know I messed up something in the way I installed geos at first
 (that's why I tried with a fresh os), so I don't know about the validity
 of my test that showed 3.7.2-dev. Please take it witfh a grain of salt.
 From my perspective, we can close this issue (not sure of the resolution
 status though: wontfix or worksforme?), as updating solved it.
 Thanks for you help pramsey, robe and Algunenano
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4462#comment:8>
