[postgis-tickets] [PostGIS] #4571: PostGIS upgrade tests trying to downgrade
trac at osgeo.org
Wed Nov 6 14:00:12 PST 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 3.0.x
Keywords: |
I think there is something wrong with our postgres upgrade regress tests
in that it's trying future versions to downgrade.
Debbie is failing on PostGIS 3.0 upgrade test with:
https://debbie.postgis.net/job/PostGIS_Regress/13498/consoleFull
15:05:26 PostgreSQL 12.0 on x86_64-pc-linux-gnu, compiled by gcc (Debian
9.2.1-9) 9.2.1 20191008, 64-bit
15:05:26 Postgis 3.0.1dev - r17988 - 2019-11-06 20:01:22
15:05:26 scripts 3.0.1dev r17988
15:05:26 GEOS: 3.9.0dev-CAPI-1.14.0
15:05:26 PROJ: 6.2.0
15:05:26
15:05:26 Running tests
15:05:26
15:22:17
psql:/var/lib/jenkins/workspace/pg/rel/pg12w64/share/postgresql/contrib/postgis-3.1/postgis.sql:2793:
ERROR: could not find function "postgis_lib_revision" in file
"/var/lib/jenkins/workspace/pg/rel/pg12w64/lib/postgresql/postgis-3.so"
15:22:17 make: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.0/raster/test/regress'
15:22:17 FAIL: upgrade unpackaged3.1--3.0.1dev
Why are future versions of PostGIS even in past test runs?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4571>
