[postgis-tickets] [PostGIS] #4571: PostGIS upgrade tests trying to downgrade
PostGIS trac at osgeo.org
Wed Nov 6 14:12:56 PST 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.0.1
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:
Description changed by robe:
Old description:
> I think there is something wrong with our postgres upgrade regress tests
> in that it's trying future versions to downgrade.
> Debbie is failing on PostGIS 3.0 upgrade test with:
> https://debbie.postgis.net/job/PostGIS_Regress/13498/consoleFull
> 15:05:26 PostgreSQL 12.0 on x86_64-pc-linux-gnu, compiled by gcc (Debian
> 9.2.1-9) 9.2.1 20191008, 64-bit
> 15:05:26   Postgis 3.0.1dev - r17988 - 2019-11-06 20:01:22
> 15:05:26   scripts 3.0.1dev r17988
> 15:05:26   GEOS: 3.9.0dev-CAPI-1.14.0
> 15:05:26   PROJ: 6.2.0
> 15:05:26
> 15:05:26 Running tests
> 15:05:26
> 15:22:17
> psql:/var/lib/jenkins/workspace/pg/rel/pg12w64/share/postgresql/contrib/postgis-3.1/postgis.sql:2793:
> ERROR:  could not find function "postgis_lib_revision" in file
> "/var/lib/jenkins/workspace/pg/rel/pg12w64/lib/postgresql/postgis-3.so"
> 15:22:17 make: Leaving directory
> '/var/lib/jenkins/workspace/postgis/branches/3.0/raster/test/regress'
> 15:22:17 FAIL: upgrade unpackaged3.1--3.0.1dev
> Why are future versions of PostGIS even in past test runs?
New description:
 15:05:26
 15:05:26
 15:22:17
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4571#comment:1>
