[postgis-tickets] [PostGIS] #4543: Use Ryū to output floating point numbers
trac at osgeo.org
Fri Nov 8 09:53:26 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.0
Component: liblwgeom | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
I've made another integration doing a simpler hack and using upstream ryu
printf's implementation and I get way less changes (some differences in
the exponent version that I still need to have a look at) and good
performance:
Before:
cartodb_dev_user_3e4a6fc6-4137-4c59-bc63-066f80efb90e_db=# explain analyze
Select ST_AsText(the_geom) from
benchmark_4c7214d90a79aa6760367a084a4d4a2f61fbe1c6cc4f7f9e76020;
QUERY PLAN
Seq Scan on
(cost=0.00..33.63 rows=13 width=32) (actual time=529.342..5680.107 rows=13
loops=1)
Planning Time: 0.039 ms
Execution Time: 5680.130 ms
(3 rows)
QUERY PLAN
Seq Scan on
(cost=0.00..33.63 rows=13 width=32) (actual time=574.798..5470.276 rows=13
loops=1)
Planning Time: 0.055 ms
Execution Time: 5470.301 ms
(3 rows)
QUERY PLAN
Seq Scan on
(cost=0.00..33.63 rows=13 width=32) (actual time=533.664..5223.448 rows=13
loops=1)
Planning Time: 0.078 ms
Execution Time: 5223.478 ms
(3 rows)
After:
QUERY PLAN
Seq Scan on
(cost=0.00..33.63 rows=13 width=32) (actual time=91.176..846.130 rows=13
loops=1)
Planning Time: 0.077 ms
Execution Time: 846.159 ms
(3 rows)
QUERY PLAN
Seq Scan on
(cost=0.00..33.63 rows=13 width=32) (actual time=82.195..840.579 rows=13
loops=1)
Planning Time: 0.052 ms
Execution Time: 840.601 ms
(3 rows)
QUERY PLAN
Seq Scan on
(cost=0.00..33.63 rows=13 width=32) (actual time=87.366..845.805 rows=13
loops=1)
Planning Time: 0.068 ms
Execution Time: 845.830 ms
(3 rows)
This new version is slower than the original hack but I've yet to
investigate why. One possibility is that the original hack never used the
exponential output, but that isn't an option for us AFAIK, right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4543#comment:1>
