[postgis-tickets] [PostGIS] #4561: ST_AsEWKT excluding Z and M in WKT representation
PostGIS trac at osgeo.org
Sun Nov 10 02:28:25 PST 2019
  Reporter:  tilt     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  low      |  Milestone:  PostGIS 3.0.1
 Component:  postgis  |    Version:  3.0.x
Resolution:  invalid  |   Keywords:
Comment (by strk):
 > Shouldn't the ''ZMSgeoms'' start converging again to the WKT specs?
 Specs are meant to be references, changes to them are not to be
 allowed. Rather, you'd end up with a _new_ reference (like a new
 version of the spec) while still needing to support to old one.
 > Only reason to keep them currently is the inclusion of the SRS, right?
 And backward compatibility.
 --strk;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4561#comment:4>
