[postgis-tickets] [PostGIS] #4561: ST_AsEWKT excluding Z and M in WKT representation
trac at osgeo.org
Sun Nov 10 01:44:10 PST 2019
Reporter: tilt | Owner: pramsey
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Resolution: invalid | Keywords:
Comment (by tilt):
OK, makes sense. I see now why this is in the documentation:
''PostGIS extended formats are currently superset of OGC one (every valid
WKB/WKT is a valid EWKB/EWKT) but this might vary in the future,
specifically if OGC comes out with a new format conflicting with our
extensions. Thus you SHOULD NOT rely on this feature!''
[https://postgis.net/docs/using_postgis_dbmanagement.html#EWKB_EWKT]
Having multiple representations that appear to mimic each other but are
differentiating on trivial points is confusing though. Shouldn't the
''ZMSgeoms'' start converging again to the WKT specs? Only reason to keep
them currently is the inclusion of the SRS, right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4561#comment:3>
