[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 27ebfe7b979c499ad36e8c94ed5b575d3e64349a
Sun Nov 10 13:48:49 PST 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  27ebfe7b979c499ad36e8c94ed5b575d3e64349a (commit)
      from  bb78dff81d8610dd3bd60efc1618b0109d129f0e (commit)
revisions in full, below.
commit 27ebfe7b979c499ad36e8c94ed5b575d3e64349a
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Nov 10 18:39:39 2019 +0300
    Timer in test runs
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 5bf3227..50e2032 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -15,6 +15,7 @@
 #$| = 1;
 use File::Basename;
 use File::Temp 'tempdir';
+use Time::HiRes qw(time);
 #use File::Which;
 use File::Copy;
 use File::Path;
@@ -456,6 +457,7 @@ foreach $TEST (@ARGV)
 	my $TEST_OBJ_COUNT_PRE;
 	my $TEST_OBJ_COUNT_POST;
+	my $TEST_START_TIME;
 	# catch a common mistake (strip trailing .sql)
 	$TEST =~ s/.sql$//;
@@ -478,23 +480,24 @@ foreach $TEST (@ARGV)
 	# create the .sql
 	# Check for .dbf not just .shp since the loader can load
 	# .dbf files without a .shp.
+	$TEST_START_TIME = time;
 	if ( -r "${TEST}.dbf" )
-		pass() if ( run_loader_test() );
+		pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if ( run_loader_test() );
 	elsif ( -r "${TEST}.tif" )
 		my $rv = run_raster_loader_test();
-		pass() if $rv;
+		pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if $rv;
 	elsif ( -r "${TEST}.sql" )
 		my $rv = run_simple_test("${TEST}.sql", "${TEST}_expected");
-		pass() if $rv;
 	elsif ( -r "${TEST}.dmp" )
-		pass() if run_dumper_test();
+		pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if run_dumper_test();
 	else
@@ -630,8 +633,8 @@ sub show_progress
 # pass <msg>
 sub pass
-  my $msg = shift;
-  printf(" ok %s\n", $msg);
+    my $msg = shift;
+    printf(" ok %s\n", $msg);
 # fail <msg> <log>
Summary of changes:
 regress/run_test.pl | 15 +++++++++------
 1 file changed, 9 insertions(+), 6 deletions(-)
hooks/post-receive
