[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. df05ab9fb5e48ee8ed2b9af5c1326afa5e13660a
git at osgeo.org
git at osgeo.org
Sun Nov 10 14:46:28 PST 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
via df05ab9fb5e48ee8ed2b9af5c1326afa5e13660a (commit)
from 27ebfe7b979c499ad36e8c94ed5b575d3e64349a (commit)
revisions in full, below.
commit df05ab9fb5e48ee8ed2b9af5c1326afa5e13660a
Author: Regina Obe <lr at pcorp.us>
Date: Sun Nov 10 17:46:24 2019 -0500
change default to newer versions and update gdal and proj links
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 5f0a12d..883c658 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,9 +1,9 @@
#!/bin/bash
set -e
if [[ "${OVERRIDE}" == '' ]] ; then
- export GEOS_VER=3.8.0rc2
- export GDAL_VER=2.2.4
- export PROJ_VER=4.9.3
+ export GEOS_VER=3.8.0
+ export GDAL_VER=2.4.3
+ export PROJ_VER=5.2.0
export SFCGAL_VER=1.3.2
export CGAL_VER=4.11
export ICON_VER=1.15
@@ -11,7 +11,7 @@ if [[ "${OVERRIDE}" == '' ]] ; then
export PROTOBUF_VER=3.2.0
export PROTOBUFC_VER=1.2.1
export JSON_VER=0.12
- export PROJSO=libproj-12.dll
+ export PROJSO=libproj-13.dll
fi;
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 0edc436..12090fe 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -17,7 +17,7 @@
#!/bin/bash
- export GDAL_VER=2.4.2
@@ -236,15 +236,19 @@ cp -r extensions/*/*.dll ${RELDIR}/${RELVERDIR}/lib #only address_standardizer i
cp -r ${RELDIR}/packaging_notes/* ${RELDIR}/${RELVERDIR}/
-echo "GEOS VERSION: ${GEOS_VER} http://trac.osgeo.org/geos" >> $verfile
-echo "GDAL VERSION: ${GDAL_VER} http://trac.osgeo.org/gdal" >> $verfile
-echo "PROJ VERSION: ${PROJ_VER} http://trac.osgeo.org/proj" >> $verfile
+echo "GEOS VERSION: ${GEOS_VER} https://trac.osgeo.org/geos" >> $verfile
+echo "GDAL VERSION: ${GDAL_VER} https://gdal.org/download.html#current-releases" >> $verfile
+echo "PROJ VERSION: ${PROJ_VER} https://proj.org/download.html#current-release" >> $verfile
if [ -n "$SFCGAL_VER" ]; then
echo "CGAL VERSION: ${CGAL_VER} http://www.cgal.org" >> $verfile
echo "BOOST VERSION: ${BOOST_VER} http://www.boost.org" >> $verfile
echo "SFCGAL VERSION: ${SFCGAL_VER} http://www.sfcgal.org https://github.com/Oslandia/SFCGAL" >> $verfile
fi;
+if [ -f ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt ]; then
+ cat $verfile ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt > $verfile
+fi
#echo "PAGC ADDRESS STANDARDIZER: http://sourceforge.net/p/pagc/code/HEAD/tree/branches/sew-refactor/postgresql " >> $verfile
cd ${RELDIR}
zip -r $package ${RELVERDIR}
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 5273001..7b83a5a 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,17 +1,17 @@
#!/bin/bash
set -e
export ZLIB_VER=1.2.11
- export PROTOBUF_VER=3.2.0
+ export PROTOBUF_VER=3.2.0
fi;
@@ -33,7 +33,7 @@ fi;
#set to something even if override is on but not set
if [[ "${LIBXML_VER}" == '' ]] ; then
- export LIBXML_VER=2.7.8
+ export LIBXML_VER=2.9.9
fi;
Summary of changes:
ci/winnie/build_postgis.sh | 8 ++++----
ci/winnie/package_postgis.sh | 12 ++++++++----
ci/winnie/regress_postgis.sh | 12 ++++++------
3 files changed, 18 insertions(+), 14 deletions(-)
hooks/post-receive
