[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 0cbdd4d61558320575c6ec9f7e775ed785bdcfee
Mon Nov 11 21:53:50 PST 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  0cbdd4d61558320575c6ec9f7e775ed785bdcfee (commit)
       via  15151172faa487dfc3489bd6ab21c9ea305a98ef (commit)
      from  e9f44e9b44b64719b33a8a6983f9e0621c6ab78f (commit)
revisions in full, below.
commit 0cbdd4d61558320575c6ec9f7e775ed785bdcfee
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Nov 10 20:15:42 2019 +0300
    Enable Link Time Optimization if available in compiler
diff --git a/NEWS b/NEWS
index 478e3ce..97c8bc4 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ PostGIS 3.1.0
   - #4539, Unify libm includes (Raúl Marín)
   - #4569, Allow unknown SRID geometry insertion into typmod SRID column (Paul Ramsey)
   - #4149, ST_Simplify(geom, 0) is now O(N) (Darafei Praliaskouski)
+  - #4574, Link Time Optimizations enabled (Darafei Praliaskouski)
 * Bug fixes *
   - #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
diff --git a/ci/travis/run_usan_clang.sh b/ci/travis/run_usan_clang.sh
index a3126ac..74226ef 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/travis/run_usan_clang.sh
@@ -3,7 +3,7 @@ set -e
 # Enable undefined behaviour sanitizer using traps
 CFLAGS_USAN="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined,implicit-conversion -fsanitize-undefined-trap-on-error -fno-sanitize-recover=implicit-conversion"
-LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
+LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro -fsanitize=undefined,implicit-conversion -fsanitize-undefined-trap-on-error -fno-sanitize-recover=implicit-conversion"
 # Sanitizer options to continue avoid stopping the runs on leaks (expected on postgres binaries)
 export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
@@ -15,5 +15,5 @@ LD_PRELOAD=/usr/lib/clang/8/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsq
 # Build with Clang and usan flags
 ./autogen.sh
-./configure CC=clang CFLAGS="${CFLAGS_USAN}" LDFLAGS="${LDFLAGS_STD}"
+./configure --enable-debug CC=clang CFLAGS="${CFLAGS_USAN}" LDFLAGS="${LDFLAGS_STD}"
 bash ./ci/travis/logbt -- make -j check RUNTESTFLAGS=--verbose
diff --git a/ci/travis/run_usan_gcc.sh b/ci/travis/run_usan_gcc.sh
index 8943dd7..8b991dd 100644
--- a/ci/travis/run_usan_gcc.sh
+++ b/ci/travis/run_usan_gcc.sh
 # Enable undefined behaviour sanitizer using traps to
 CFLAGS_STD="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined -fsanitize-undefined-trap-on-error"
+LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro -fsanitize=undefined"
 /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
 ./autogen.sh
diff --git a/configure.ac b/configure.ac
index 103589e..db77736 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1128,6 +1128,8 @@ if test $ENABLE_DEBUG -eq 1; then
 else
     AC_DEFINE([PARANOIA_LEVEL], [0], [Disable use of memory checks])
     AC_DEFINE([NDEBUG], [0], [Disable C asserts])
+    AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -flto], [_cv_flto], [-flto], [], [CFLAGS="$CFLAGS -flto"], [])
+    AC_LIBTOOL_LINKER_OPTION([if $compiler supports -flto], [_cv_flto], [[-flto]], [LDFLAGS="$LDFLAGS -flto"])
 fi
commit 15151172faa487dfc3489bd6ab21c9ea305a98ef
Date:   Sun Nov 10 21:01:52 2019 +0300
    Fix maybe-unitialized warnings
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index a9bb846..4d31a62 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -432,9 +432,10 @@ static void test_lwpoint_get_ordinate(void)
-static void test_point_interpolate(void)
+static void
+test_point_interpolate(void)
-	POINT4D p, q, r;
+	POINT4D p, q, r = {0, 0, 0, 0};
 	int rv = 0;
 	p.x = 10.0;
@@ -448,21 +449,20 @@ static void test_point_interpolate(void)
 	q.m = 50.0;
 	rv = point_interpolate(&p, &q, &r, 1, 1, 'Z', 35.0);
-	CU_ASSERT_EQUAL( rv, LW_SUCCESS );
-	CU_ASSERT_EQUAL( r.x, 15.0);
+	CU_ASSERT_EQUAL(rv, LW_SUCCESS);
+	CU_ASSERT_EQUAL(r.x, 15.0);
 	rv = point_interpolate(&p, &q, &r, 1, 1, 'M', 41.0);
-	CU_ASSERT_EQUAL( r.y, 21.0);
+	CU_ASSERT_EQUAL(r.y, 21.0);
 	rv = point_interpolate(&p, &q, &r, 1, 1, 'M', 50.0);
-	CU_ASSERT_EQUAL( r.y, 30.0);
+	CU_ASSERT_EQUAL(r.y, 30.0);
 	rv = point_interpolate(&p, &q, &r, 1, 1, 'M', 40.0);
-	CU_ASSERT_EQUAL( r.y, 20.0);
+	CU_ASSERT_EQUAL(r.y, 20.0);
 static void test_lwline_interpolate_points(void)
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index 64b74c9..313a767 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -270,34 +270,30 @@ getPoint3dm_p(const POINTARRAY *pa, uint32_t n, POINT3DM *op)
 	uint8_t *ptr;
 	int zmflag;
-	if ( ! pa )
+	if (!pa)
 		lwerror("%s [%d] NULL POINTARRAY input", __FILE__, __LINE__);
-		return 0;
+		return LW_FALSE;
-	if ( n>=pa->npoints )
+	if (n >= pa->npoints)
 		lwerror("%s [%d] called with n=%d and npoints=%d", __FILE__, __LINE__, n, pa->npoints);
-		return 0;
+		return LW_FALSE;
-	LWDEBUGF(2, "getPoint3dm_p(%d) called on array of %d-dimensions / %u pts",
-	         n, FLAGS_NDIMS(pa->flags), pa->npoints);
 	/* Get a pointer to nth point offset and zmflag */
-	ptr=getPoint_internal(pa, n);
-	zmflag=FLAGS_GET_ZM(pa->flags);
+	ptr = getPoint_internal(pa, n);
+	zmflag = FLAGS_GET_ZM(pa->flags);
 	 * if input POINTARRAY has the M and NO Z,
 	 * we can issue a single memcpy
-	if ( zmflag == 1 )
+	if (zmflag == 1)
 		memcpy(op, ptr, sizeof(POINT3DM));
-		return 1;
+		return LW_TRUE;
@@ -311,20 +307,17 @@ getPoint3dm_p(const POINTARRAY *pa, uint32_t n, POINT3DM *op)
 	 * copy next double, otherwise initialize
 	 * M to NO_M_VALUE
-	if ( zmflag == 3 )
+	if (zmflag == 3)
-		ptr+=sizeof(POINT3DZ);
+		ptr += sizeof(POINT3DZ);
 		memcpy(&(op->m), ptr, sizeof(double));
 	else
-		op->m=NO_M_VALUE;
+		op->m = NO_M_VALUE;
-	return 1;
+	return LW_TRUE;
  * Copy a point from the point array into the parameter point
  * z value (if present) is not returned.
diff --git a/liblwgeom/lwline.c b/liblwgeom/lwline.c
index 71efd45..4406b07 100644
--- a/liblwgeom/lwline.c
+++ b/liblwgeom/lwline.c
@@ -453,31 +453,34 @@ lwline_is_closed(const LWLINE *line)
 int
 lwline_is_trajectory(const LWLINE *line)
-  POINT3DM p;
-  int i, n;
-  double m = -1 * FLT_MAX;
-  if ( ! FLAGS_GET_M(line->flags) ) {
-    lwnotice("Line does not have M dimension");
-    return LW_FALSE;
-  n = line->points->npoints;
-  if ( n < 2 ) return LW_TRUE; /* empty or single-point are "good" */
-  for (i=0; i<n; ++i) {
-    getPoint3dm_p(line->points, i, &p);
-    if ( p.m <= m ) {
-      lwnotice("Measure of vertex %d (%g) not bigger than measure of vertex %d (%g)",
-        i, p.m, i-1, m);
-      return LW_FALSE;
-    m = p.m;
-  return LW_TRUE;
+	if (!FLAGS_GET_M(line->flags))
+		lwnotice("Line does not have M dimension");
+		return LW_FALSE;
+	uint32_t n = line->points->npoints;
+	if (n < 2)
+		return LW_TRUE; /* empty or single-point are "good" */
+	double m = -1 * FLT_MAX;
+	for (uint32_t i = 0; i < n; ++i)
+		POINT3DM p;
+		if (!getPoint3dm_p(line->points, i, &p))
+			return LW_FALSE;
+		if (p.m <= m)
+			lwnotice(
+			    "Measure of vertex %d (%g) not bigger than measure of vertex %d (%g)", i, p.m, i - 1, m);
+			return LW_FALSE;
+		m = p.m;
+	return LW_TRUE;
 LWLINE*
 lwline_force_dims(const LWLINE *line, int hasz, int hasm)
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index 859b36d..552ae0d 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -839,10 +839,7 @@ int
 ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	SHPObject *obj = NULL;
-	int j, z;
 	int ret = SHPLOADEROK;
-	int field_precision, field_width;
 	char name[MAXFIELDNAMELEN];
 	char name2[MAXFIELDNAMELEN];
 	DBFFieldType type = FTInvalid;
@@ -905,7 +902,7 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 		if (state->config->null_policy == POLICY_NULL_ABORT)
 			/* If we abort on null items, scan the entire file for NULLs */
-			for (j = 0; j < state->num_entities; j++)
+			for (int j = 0; j < state->num_entities; j++)
 				obj = SHPReadObject(state->hSHPHandle, j);
@@ -1104,8 +1101,9 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	/* Generate a string of comma separated column names of the form "col1, col2 ... colN" for the SQL
 	   insertion string */
-	for (j = 0; j < state->num_fields; j++)
+	for (int j = 0; j < state->num_fields; j++)
+		int field_precision = 0, field_width = 0;
 		type = DBFGetFieldInfo(state->hDBFHandle, j, name, &field_width, &field_precision);
 		state->types[j] = type;
@@ -1183,7 +1181,7 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 		/* Avoid duplicating field names */
-		for (z = 0; z < j ; z++)
+		for (int z = 0; z < j; z++)
 			if (strcmp(state->field_names[z], name) == 0)
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index 9d02a34..e75a89b 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -1708,92 +1708,79 @@ rt_raster_to_gdal(
  * @return set of "gdaldriver" values of available GDAL drivers
 rt_gdaldriver
-rt_raster_gdal_drivers(uint32_t *drv_count, uint8_t can_write) {
-	const char *cc;
-	const char *vio;
-	const char *txt;
-	int txt_len;
-	GDALDriverH *drv = NULL;
-	rt_gdaldriver rtn = NULL;
-	int count;
-	int i;
-	uint32_t j;
+rt_raster_gdal_drivers(uint32_t *drv_count, uint8_t can_write)
 	assert(drv_count != NULL);
+	uint32_t output_driver = 0;
 	rt_util_gdal_register_all(0);
-	count = GDALGetDriverCount();
-	RASTER_DEBUGF(3, "%d drivers found", count);
+	uint32_t count = (uint32_t)GDALGetDriverCount();
-	rtn = (rt_gdaldriver) rtalloc(count * sizeof(struct rt_gdaldriver_t));
-	if (NULL == rtn) {
+	rt_gdaldriver rtn = (rt_gdaldriver)rtalloc(count * sizeof(struct rt_gdaldriver_t));
+	if (!rtn)
 		rterror("rt_raster_gdal_drivers: Could not allocate memory for gdaldriver structure");
-		return 0;
+		*drv_count = output_driver;
+		return NULL;
-	for (i = 0, j = 0; i < count; i++) {
-		drv = GDALGetDriver(i);
+	for (uint32_t i = 0; i < count; i++)
+		GDALDriverH *drv = GDALGetDriver(i);
 #ifdef GDAL_DCAP_RASTER
 		/* Starting with GDAL 2.0, vector drivers can also be returned */
 		/* Only keep raster drivers */
 		const char *is_raster;
 		is_raster = GDALGetMetadataItem(drv, GDAL_DCAP_RASTER, NULL);
-		if (is_raster == NULL || !EQUAL(is_raster, "YES"))
+		if (!is_raster || !EQUAL(is_raster, "YES"))
 			continue;
 #endif
 		/* CreateCopy support */
-		cc = GDALGetMetadataItem(drv, GDAL_DCAP_CREATECOPY, NULL);
+		const char *cc = GDALGetMetadataItem(drv, GDAL_DCAP_CREATECOPY, NULL);
+		if (can_write && !cc)
+			continue;
 		/* VirtualIO support */
-		vio = GDALGetMetadataItem(drv, GDAL_DCAP_VIRTUALIO, NULL);
-		if (can_write && (cc == NULL || vio == NULL))
+		const char *vio = GDALGetMetadataItem(drv, GDAL_DCAP_VIRTUALIO, NULL);
+		if (can_write && !vio)
 			continue;
 		/* we can always read what GDAL can load */
-		rtn[j].can_read = 1;
+		rtn[output_driver].can_read = 1;
 		/* we require CreateCopy and VirtualIO support to write to GDAL */
-		rtn[j].can_write = (cc != NULL && vio != NULL);
-		if (rtn[j].can_write) {
-			RASTER_DEBUGF(3, "driver %s (%d) supports CreateCopy() and VirtualIO()", txt, i);
+		rtn[output_driver].can_write = (cc != NULL && vio != NULL);
 		/* index of driver */
-		rtn[j].idx = i;
+		rtn[output_driver].idx = i;
 		/* short name */
-		txt = GDALGetDriverShortName(drv);
-		txt_len = strlen(txt);
+		const char *txt = GDALGetDriverShortName(drv);
+		size_t txt_len = strlen(txt);
 		txt_len = (txt_len + 1) * sizeof(char);
-		rtn[j].short_name = (char *) rtalloc(txt_len);
-		memcpy(rtn[j].short_name, txt, txt_len);
+		rtn[output_driver].short_name = (char *)rtalloc(txt_len);
+		memcpy(rtn[output_driver].short_name, txt, txt_len);
 		/* long name */
 		txt = GDALGetDriverLongName(drv);
-		rtn[j].long_name = (char *) rtalloc(txt_len);
-		memcpy(rtn[j].long_name, txt, txt_len);
+		rtn[output_driver].long_name = (char *)rtalloc(txt_len);
+		memcpy(rtn[output_driver].long_name, txt, txt_len);
 		/* creation options */
 		txt = GDALGetDriverCreationOptionList(drv);
-		rtn[j].create_options = (char *) rtalloc(txt_len);
-		memcpy(rtn[j].create_options, txt, txt_len);
+		rtn[output_driver].create_options = (char *)rtalloc(txt_len);
+		memcpy(rtn[output_driver].create_options, txt, txt_len);
-		j++;
+		output_driver++;
 	/* free unused memory */
-	rtn = rtrealloc(rtn, j * sizeof(struct rt_gdaldriver_t));
-	*drv_count = j;
+	rtn = rtrealloc(rtn, output_driver * sizeof(struct rt_gdaldriver_t));
 	return rtn;
Summary of changes:
 NEWS                           |  1 +
 ci/travis/run_usan_clang.sh    |  4 +--
 ci/travis/run_usan_gcc.sh      |  2 +-
 configure.ac                   |  2 ++
 liblwgeom/cunit/cu_algorithm.c | 22 ++++++------
 liblwgeom/lwgeom_api.c         | 31 +++++++----------
 liblwgeom/lwline.c             | 51 +++++++++++++++-------------
 loader/shp2pgsql-core.c        | 10 +++---
 raster/rt_core/rt_raster.c     | 77 ++++++++++++++++++------------------------
 9 files changed, 92 insertions(+), 108 deletions(-)
hooks/post-receive
