[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 866b3c800e5881d7123a545a693c207f12de37ca
Mon Nov 11 22:15:16 PST 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  866b3c800e5881d7123a545a693c207f12de37ca (commit)
       via  cc500d1bfddf46c1f2c1942372e0ea976c07ed1f (commit)
      from  0cbdd4d61558320575c6ec9f7e775ed785bdcfee (commit)
revisions in full, below.
commit 866b3c800e5881d7123a545a693c207f12de37ca
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Oct 31 17:56:19 2019 +0300
    ptarray_snap_to_grid: write to ptarray only once per point.
diff --git a/NEWS b/NEWS
index 169371b..6f80c2d 100644
--- a/NEWS
+++ b/NEWS
@@ -14,7 +14,8 @@ PostGIS 3.1.0
   - #4539, Unify libm includes (Raúl Marín)
   - #4569, Allow unknown SRID geometry insertion into typmod SRID column (Paul Ramsey)
   - #4149, ST_Simplify(geom, 0) is now O(N).
-           ST_Affine (ST_Translate, ST_TransScale, ST_Rotate) optimized. (Darafei Praliaskouski)
+           ST_Affine (ST_Translate, ST_TransScale, ST_Rotate) optimized.
+           ST_SnapToGrid optimized. (Darafei Praliaskouski)
   - #4574, Link Time Optimizations enabled (Darafei Praliaskouski)
 * Bug fixes *
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 8b1858b..1a12fca 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -2007,63 +2007,58 @@ ptarray_startpoint(const POINTARRAY *pa, POINT4D *pt)
 void
 ptarray_grid_in_place(POINTARRAY *pa, const gridspec *grid)
-	uint32_t i, j = 0;
+	uint32_t j = 0;
 	POINT4D *p, *p_out = NULL;
-	int ndims = FLAGS_NDIMS(pa->flags);
-	int has_z = FLAGS_GET_Z(pa->flags);
-	int has_m = FLAGS_GET_M(pa->flags);
-	LWDEBUGF(2, "%s called on %p", __func__, pa);
+	double x, y, z = 0, m = 0;
+	uint32_t ndims = FLAGS_NDIMS(pa->flags);
+	uint32_t has_z = FLAGS_GET_Z(pa->flags);
+	uint32_t has_m = FLAGS_GET_M(pa->flags);
-	for (i = 0; i < pa->npoints; i++)
+	for (uint32_t i = 0; i < pa->npoints; i++)
 		/* Look straight into the abyss */
-		p = (POINT4D*)(getPoint_internal(pa, i));
+		p = (POINT4D *)(getPoint_internal(pa, i));
+		x = p->x;
+		y = p->y;
+		if (ndims > 2)
+			z = p->z;
+		if (ndims > 3)
+			m = p->m;
 		if (grid->xsize > 0)
-			p->x = rint((p->x - grid->ipx)/grid->xsize) * grid->xsize + grid->ipx;
+			x = rint((x - grid->ipx) / grid->xsize) * grid->xsize + grid->ipx;
 		if (grid->ysize > 0)
-			p->y = rint((p->y - grid->ipy)/grid->ysize) * grid->ysize + grid->ipy;
+			y = rint((y - grid->ipy) / grid->ysize) * grid->ysize + grid->ipy;
 		/* Read and round this point */
 		/* Z is always in third position */
-		if (has_z)
-			if (grid->zsize > 0)
-				p->z = rint((p->z - grid->ipz)/grid->zsize) * grid->zsize + grid->ipz;
+		if (has_z && grid->zsize > 0)
+			z = rint((z - grid->ipz) / grid->zsize) * grid->zsize + grid->ipz;
 		/* M might be in 3rd or 4th position */
-		if (has_m)
+		if (has_m && grid->msize > 0)
-			/* In POINT M, M is in 3rd position */
-			if (grid->msize > 0 && !has_z)
-				p->z = rint((p->z - grid->ipm)/grid->msize) * grid->msize + grid->ipm;
-			/* In POINT ZM, M is in 4th position */
-			if (grid->msize > 0 && has_z)
-				p->m = rint((p->m - grid->ipm)/grid->msize) * grid->msize + grid->ipm;
+			/* In POINT ZM, M is in 4th position, in POINT M, M is in 3rd position which is Z in POINT4D */
+			if (has_z)
+				m = rint((m - grid->ipm) / grid->msize) * grid->msize + grid->ipm;
+			else
+				z = rint((z - grid->ipm) / grid->msize) * grid->msize + grid->ipm;
 		/* Skip duplicates */
-		if ( p_out && FP_EQUALS(p_out->x, p->x) && FP_EQUALS(p_out->y, p->y)
-		   && (ndims > 2 ? FP_EQUALS(p_out->z, p->z) : 1)
-		   && (ndims > 3 ? FP_EQUALS(p_out->m, p->m) : 1) )
+		if (p_out && p_out->x == x && p_out->y == y && (ndims > 2 ? p_out->z == z : 1) &&
+		    (ndims > 3 ? p_out->m == m : 1))
 			continue;
 		/* Write rounded values into the next available point */
-		p_out = (POINT4D*)(getPoint_internal(pa, j++));
-		p_out->x = p->x;
-		p_out->y = p->y;
+		p_out = (POINT4D *)(getPoint_internal(pa, j++));
+		p_out->x = x;
+		p_out->y = y;
 		if (ndims > 2)
-			p_out->z = p->z;
+			p_out->z = z;
 		if (ndims > 3)
-			p_out->m = p->m;
+			p_out->m = m;
 	/* Update output ptarray length */
@@ -2071,7 +2066,6 @@ ptarray_grid_in_place(POINTARRAY *pa, const gridspec *grid)
 	return;
 int
 ptarray_npoints_in_rect(const POINTARRAY *pa, const GBOX *gbox)
commit cc500d1bfddf46c1f2c1942372e0ea976c07ed1f
Date:   Thu Oct 31 17:00:29 2019 +0300
    ptarray_affine: operate on ptarray directly.
index 97c8bc4..169371b 100644
--- a/NEWS
+++ b/NEWS
@@ -13,7 +13,8 @@ PostGIS 3.1.0
 * Enhancements *
-  - #4149, ST_Simplify(geom, 0) is now O(N) (Darafei Praliaskouski)
+  - #4149, ST_Simplify(geom, 0) is now O(N).
+           ST_Affine (ST_Translate, ST_TransScale, ST_Rotate) optimized. (Darafei Praliaskouski)
 * Bug fixes *
index 9894336..8b1858b 100644
@@ -1806,49 +1806,30 @@ ptarray_length(const POINTARRAY *pts)
 void
 ptarray_affine(POINTARRAY *pa, const AFFINE *a)
-	uint32_t i;
-	double x,y,z;
-	POINT4D p4d;
-	LWDEBUG(2, "lwgeom_affine_ptarray start");
-	if ( FLAGS_GET_Z(pa->flags) )
+	if (FLAGS_GET_Z(pa->flags))
-		LWDEBUG(3, " has z");
-		for (i=0; i<pa->npoints; i++)
-			getPoint4d_p(pa, i, &p4d);
-			x = p4d.x;
-			y = p4d.y;
-			z = p4d.z;
-			p4d.x = a->afac * x + a->bfac * y + a->cfac * z + a->xoff;
-			p4d.y = a->dfac * x + a->efac * y + a->ffac * z + a->yoff;
-			p4d.z = a->gfac * x + a->hfac * y + a->ifac * z + a->zoff;
-			ptarray_set_point4d(pa, i, &p4d);
-			LWDEBUGF(3, " POINT %g %g %g => %g %g %g", x, y, z, p4d.x, p4d.y, p4d.z);
+			POINT4D *p4d = (POINT4D *)(getPoint_internal(pa, i));
+			double x = p4d->x;
+			double y = p4d->y;
+			double z = p4d->z;
+			p4d->x = a->afac * x + a->bfac * y + a->cfac * z + a->xoff;
+			p4d->y = a->dfac * x + a->efac * y + a->ffac * z + a->yoff;
+			p4d->z = a->gfac * x + a->hfac * y + a->ifac * z + a->zoff;
 	else
-		LWDEBUG(3, " doesn't have z");
-			x = p4d.x;
-			y = p4d.y;
-			p4d.x = a->afac * x + a->bfac * y + a->xoff;
-			p4d.y = a->dfac * x + a->efac * y + a->yoff;
-			LWDEBUGF(3, " POINT %g %g => %g %g", x, y, p4d.x, p4d.y);
+			POINT2D *pt = (POINT2D *)(getPoint_internal(pa, i));
+			double x = pt->x;
+			double y = pt->y;
+			pt->x = a->afac * x + a->bfac * y + a->xoff;
+			pt->y = a->dfac * x + a->efac * y + a->yoff;
-	LWDEBUG(3, "lwgeom_affine_ptarray end");
Summary of changes:
 NEWS                |   4 +-
 liblwgeom/ptarray.c | 117 +++++++++++++++++++++-------------------------------
 2 files changed, 49 insertions(+), 72 deletions(-)
hooks/post-receive
