[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. ff0845764e7fdb182abf2f5d5f0df1d1fc64bcd3
git at osgeo.org
git at osgeo.org
Fri Nov 15 03:07:47 PST 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
via ff0845764e7fdb182abf2f5d5f0df1d1fc64bcd3 (commit)
from de298f1b42a8ae2e8c7f9137d904712c33bf9c45 (commit)
revisions in full, below.
commit ff0845764e7fdb182abf2f5d5f0df1d1fc64bcd3
Author: Raúl Marín <git at rmr.ninja>
Date: Fri Nov 15 10:56:32 2019 +0100
Drop postgis_proc_set_search_path.pl
Closes #4579
diff --git a/.gitignore b/.gitignore
index 5213c3b..bc0d770 100644
--- a/.gitignore
+++ b/.gitignore
@@ -108,7 +108,6 @@ postgis/legacy_gist.sql
postgis/legacy_minimal.sql
postgis/legacy.sql
postgis/postgis.sql
-postgis/postgis_proc_set_search_path.sql
postgis/postgis_for_extension.sql
postgis/postgis_upgrade.sql*
postgis/postgis_upgrade_for_extension.sql
@@ -128,7 +127,6 @@ raster/rt_pg/Makefile
raster/rt_pg/rtpostgis.sql
raster/rt_pg/rtpostgis_drop.sql
raster/rt_pg/rtpostgis_legacy.sql
-raster/rt_pg/rtpostgis_proc_set_search_path.sql
raster/rt_pg/rtpostgis_for_extension.sql
raster/rt_pg/rtpostgis_upgrade.sql.in
raster/rt_pg/rtpostgis_upgrade*.sql
diff --git a/NEWS b/NEWS
index bf91482..13e1b4b 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ PostGIS 3.1.0
* Breaking changes *
- #4577, Drop support for PostgreSQL 9.5 (Raúl Marín)
+ - #4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)
* New features *
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 5293e0c..3f0b40d 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -34,7 +34,7 @@ MODULE_big=postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
endif
# Files to be copied to the contrib/ directory
-SQL_built=postgis.sql uninstall_postgis.sql postgis_upgrade.sql postgis_proc_set_search_path.sql legacy.sql uninstall_legacy.sql legacy_minimal.sql legacy_gist.sql
+SQL_built=postgis.sql uninstall_postgis.sql postgis_upgrade.sql legacy.sql uninstall_legacy.sql legacy_minimal.sql legacy_gist.sql
DATA=../spatial_ref_sys.sql
# SQL objects (files requiring pre-processing)
@@ -241,8 +241,6 @@ endif
postgis_upgrade.sql.in: postgis.sql ../utils/postgis_proc_upgrade.pl
$(PERL) ../utils/postgis_proc_upgrade.pl $< UNUSED > $@
-postgis_proc_set_search_path.sql: postgis.sql ../utils/postgis_proc_set_search_path.pl
- $(PERL) ../utils/postgis_proc_set_search_path.pl $< UNUSED > $@
postgis_upgrade.sql: postgis_before_upgrade.sql postgis_upgrade.sql.in postgis_after_upgrade.sql
echo "BEGIN;" > $@
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index ef83534..96a5a37 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -31,7 +31,7 @@ MODULE_big=$(MODULE_NAME)- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
endif
-DATA_built=rtpostgis.sql rtpostgis_upgrade.sql rtpostgis_proc_set_search_path.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql
+DATA_built=rtpostgis.sql rtpostgis_upgrade.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql
DATA=
# SQL preprocessor
@@ -137,9 +137,6 @@ $(SQL_OBJS): ../../postgis/sqldefines.h ../../postgis_revision.h
rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/postgis_proc_upgrade.pl
$(PERL) ../../utils/postgis_proc_upgrade.pl $< UNUSED > $@
-rtpostgis_proc_set_search_path.sql: rtpostgis.sql ../../utils/postgis_proc_set_search_path.pl
- $(PERL) ../../utils/postgis_proc_set_search_path.pl $< UNUSED > $@
rtpostgis_upgrade.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade.sql.in rtpostgis_drop.sql
echo 'BEGIN;' > $@
cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 50e2032..16a1290 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1479,7 +1479,6 @@ sub prepare_spatial
# Load postgis.sql into the database
load_sql_file("${scriptdir}/postgis.sql", 1);
load_sql_file("${scriptdir}/postgis_comments.sql", 0);
- load_sql_file("${scriptdir}/postgis_proc_set_search_path.sql", 0);
load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
if ( $OPT_WITH_TOPO )
@@ -1494,7 +1493,6 @@ sub prepare_spatial
print "Loading Raster into '${DB}'\n";
load_sql_file("${scriptdir}/rtpostgis.sql", 1);
load_sql_file("${scriptdir}/raster_comments.sql", 0);
- load_sql_file("${scriptdir}/rtpostgis_proc_set_search_path.sql", 0);
if ( $OPT_WITH_SFCGAL )
diff --git a/utils/postgis_proc_set_search_path.pl b/utils/postgis_proc_set_search_path.pl
deleted file mode 100644
index 8425787..0000000
--- a/utils/postgis_proc_set_search_path.pl
+++ /dev/null
@@ -1,183 +0,0 @@
-#!/usr/bin/perl -w
-# PostGIS - Spatial Types for PostgreSQL
-# http://postgis.net
-# Copyright (C) 2016 Regina Obe <lr at pcorp.us>
-# This is free software; you can redistribute and/or modify it under
-# the terms of the GNU General Public Licence. See the COPYING file.
-# This script produces an .sql file containing
-# ALTER FUNCTION SET PATH calls for each function
-# in postgis.sql
-# Having postgis functions force the search path
-# to just where postgis is installed is needed
-# so that functions that call other functions during
-# database restore, materialized view creation, foreign table calls
-# will always be able to find the companion functions
-eval "exec perl -w $0 $@"
- if (0);
-use strict;
-use warnings;
-# Commandline argument handling
-($#ARGV == 0) ||
-die "Usage: perl postgis_proc_set_path.pl <postgis.sql> <version_from> [<schema>]\nCreates a new SQL script
-to set search path for all functions in input script file.\n"
- if ( @ARGV < 1 || @ARGV > 3 );
-my $sql_file = $ARGV[0];
-my $module = 'postgis';
-my $soname = '';
-my $version_to = "";
-my $version_to_num = 0;
-my $version_from = $ARGV[1];
-my $version_from_num = 0;
-my $schema = "";
-$schema = $ARGV[2] if @ARGV > 2;
-die "Unable to open input SQL file $sql_file\n"
- if ( ! -f $sql_file );
-## Header of do
-print 'DO language plpgsql $$';
-my $dofunc_start = <<"EOF";
-DECLARE param_postgis_schema text;
-BEGIN
--- check if PostGIS is already installed
-param_postgis_schema = (SELECT n.nspname from pg_extension e join pg_namespace n on e.extnamespace = n.oid WHERE extname = 'postgis');
--- if in middle install, it will be the current_schema or what was there already
-param_postgis_schema = COALESCE(param_postgis_schema, current_schema());
-IF param_postgis_schema != current_schema() THEN
- EXECUTE 'set search_path TO ' || quote_ident(param_postgis_schema);
-END IF;
--- PostGIS set search path of functions
-EOF
-print $dofunc_start;
-# Search the SQL file for the target version number (the
-# version we are upgrading *to*.
-open( INPUT, $sql_file ) || die "Couldn't open file: $sql_file\n";
-print qq{
--- ALTER FUNCTION script
-#print "BEGIN;\n";
-print "SET search_path TO $schema;\n" if $schema;
-# Go through the SQL file and find all functions
-# for each create an ALTER FUNCTION statement
-# to set the search_path to schema postgis is installed in
-while(<INPUT>)
- if ( /^create or replace function([^\)]+)([\)]{0,1})/i )
- my $funchead = $1; # contains function header except the end )
- my $endhead = 0;
- my $endfunchead = $2;
- my $search_path_safe = -1; # we can put a search path on it without disrupting spatial index use
- if ($2 eq ')') ## reached end of header
- $endhead = 1;
- if ( /((add|drop)[\_]*(geometry|overview|raster)|internal)/i){
- # can't put search_path on addgeometrycolumn or addrasterconstraints
- # since table names are sometimes passed in non-qualified
- # also can't work on some functions that take internals
- $search_path_safe = 0;
- if ( /st_transform/i){
- # st_transform functions query spatial_ref_sys
- # so could fail in materialized views and spatial indexes,
- # though often all done in C
- $search_path_safe = 1;
- #raster folks decided to break their func head in multiple lines
- # so we need to do this crazy thing
- if ($endhead != 1)
- while(<INPUT>)
- #look for expressions with no ( and optionally ending in )
- if ( /^([^\)]*)([\)]{0,1})/i )
- $funchead .= $1;
- $endfunchead = $2;
- $endhead = 1;
- last if ( $endhead );
- #strip quoted , trips up the default strip
- $funchead =~ s/(',')+//ig;
- #strip off default args from the function header
- $funchead =~ s/(default\s+[A-Za-z\.\+\-0-9\'\[\]\:\s]*)//ig;
- #check to see if function is STRICT or c or plpgsql
- # we can't put search path on non-STRICT sql since search path breaks SQL inlining
- # breaking sql inlining will break use of spatial index
- my $endfunc = 0;
- while(<INPUT>)
- $endfunc = 1 if /^\s*(\$\$\s*)?LANGUAGE /i;
- if ( $endfunc == 1 && $search_path_safe == -1 ){
- $search_path_safe = 1 if /LANGUAGE\s+[\']*(plpgsql)/i;
- $search_path_safe = 1 if /STRICT/i;
- #exclude C functions unless we've include,
- # in most cases except ST_Transform
- # c functions don't call dependent functions or tables
- $search_path_safe = 0 if /LANGUAGE\s+[\']*(c)/i;
- last if ( $endfunc && /\;/ );
- if ($search_path_safe == 1)
- print "EXECUTE 'ALTER FUNCTION $funchead $endfunchead SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';\n";
-close( INPUT );
-## End of DO
-print 'END;';
-print '$$;';
-__END__
Summary of changes:
.gitignore | 2 -
NEWS | 1 +
postgis/Makefile.in | 4 +-
raster/rt_pg/Makefile.in | 5 +-
regress/run_test.pl | 2 -
utils/postgis_proc_set_search_path.pl | 183 ----------------------------------
6 files changed, 3 insertions(+), 194 deletions(-)
delete mode 100644 utils/postgis_proc_set_search_path.pl
hooks/post-receive
