[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 5df3bbbf927e10b16905d915ee7880e9498bf9c3
Fri Nov 15 07:05:53 PST 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  5df3bbbf927e10b16905d915ee7880e9498bf9c3 (commit)
       via  5fb9aa680ba1516d1ad898f851f3a68345203587 (commit)
      from  ff0845764e7fdb182abf2f5d5f0df1d1fc64bcd3 (commit)
revisions in full, below.
commit 5df3bbbf927e10b16905d915ee7880e9498bf9c3
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Nov 15 15:46:43 2019 +0100
    postgis/postgis.sql.in: Add missing parallel tags
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 0234963..e3c93a1 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4987,7 +4987,7 @@ CREATE OR REPLACE FUNCTION ST_AsText(geometry)
 CREATE OR REPLACE FUNCTION ST_AsText(geometry, int4)
     RETURNS TEXT
     AS 'MODULE_PATHNAME','LWGEOM_asText'
-    LANGUAGE 'c' IMMUTABLE STRICT
+    LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
     _COST_MEDIUM;
 -- Availability: 1.2.2
@@ -6232,7 +6232,7 @@ CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFA
 -- has to be here because need ST_StartPoint
 CREATE OR REPLACE FUNCTION ST_Angle(line1 geometry, line2 geometry)
 	RETURNS float8 AS 'SELECT ST_Angle(St_StartPoint($1), ST_EndPoint($1), St_StartPoint($2), ST_EndPoint($2))'
-	LANGUAGE 'sql' IMMUTABLE STRICT;
+	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
 -- make views and spatial_ref_sys public viewable --
 GRANT SELECT ON TABLE geography_columns TO public;
commit 5fb9aa680ba1516d1ad898f851f3a68345203587
Date:   Fri Nov 15 15:46:25 2019 +0100
    Add parallellism and cost properties to brin functions
    Closes #4578
diff --git a/postgis/postgis_brin.sql.in b/postgis/postgis_brin.sql.in
index 369e00e..340dd1f 100644
--- a/postgis/postgis_brin.sql.in
+++ b/postgis/postgis_brin.sql.in
@@ -11,37 +11,37 @@
 CREATE OR REPLACE FUNCTION contains_2d(box2df, geometry)
 RETURNS boolean
 AS 'MODULE_PATHNAME','gserialized_contains_box2df_geom_2d'
-LANGUAGE 'c' IMMUTABLE STRICT;
+LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE _COST_DEFAULT;
 -- Availability: 2.3.0
 CREATE OR REPLACE FUNCTION is_contained_2d(box2df, geometry)
 RETURNS boolean
 AS 'MODULE_PATHNAME','gserialized_within_box2df_geom_2d'
 CREATE OR REPLACE FUNCTION overlaps_2d(box2df, geometry)
 RETURNS boolean
 AS 'MODULE_PATHNAME','gserialized_overlaps_box2df_geom_2d'
 CREATE OR REPLACE FUNCTION overlaps_2d(box2df, box2df)
 RETURNS boolean
 AS 'MODULE_PATHNAME','gserialized_contains_box2df_box2df_2d'
 CREATE OR REPLACE FUNCTION contains_2d(box2df, box2df)
 RETURNS boolean
 CREATE OR REPLACE FUNCTION is_contained_2d(box2df, box2df)
 RETURNS boolean
 CREATE OPERATOR ~ (
@@ -72,21 +72,21 @@ CREATE OR REPLACE FUNCTION contains_2d(geometry, box2df)
 RETURNS boolean
 AS
 	'SELECT $2 OPERATOR(@extschema at .@) $1;'
-LANGUAGE SQL IMMUTABLE STRICT;
+LANGUAGE SQL IMMUTABLE STRICT PARALLEL SAFE _COST_DEFAULT;
 CREATE OR REPLACE FUNCTION is_contained_2d(geometry, box2df)
 RETURNS boolean
 AS
 	'SELECT $2 OPERATOR(@extschema at .~) $1;'
 CREATE OR REPLACE FUNCTION overlaps_2d(geometry, box2df)
 RETURNS boolean
 AS
 	'SELECT $2 OPERATOR(@extschema at .&&) $1;'
 CREATE OPERATOR ~ (
@@ -139,13 +139,13 @@ CREATE OPERATOR ~ (
 CREATE OR REPLACE FUNCTION overlaps_nd(gidx, geometry)
 RETURNS boolean
 AS 'MODULE_PATHNAME','gserialized_gidx_geom_overlaps'
 CREATE OR REPLACE FUNCTION overlaps_nd(gidx, gidx)
 RETURNS boolean
 AS 'MODULE_PATHNAME','gserialized_gidx_gidx_overlaps'
 CREATE OPERATOR &&& (
@@ -160,7 +160,7 @@ CREATE OR REPLACE FUNCTION overlaps_nd(geometry, gidx)
 RETURNS boolean
 AS
 	'SELECT $2 OPERATOR(@extschema at .&&&) $1;'
@@ -187,19 +187,22 @@ CREATE OPERATOR &&& (
-CREATE OR REPLACE FUNCTION geom2d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
-	AS 'MODULE_PATHNAME','geom2d_brin_inclusion_add_value'
-	LANGUAGE 'c';
+CREATE OR REPLACE FUNCTION geom2d_brin_inclusion_add_value(internal, internal, internal, internal)
+RETURNS boolean
+AS 'MODULE_PATHNAME','geom2d_brin_inclusion_add_value'
+LANGUAGE 'c' PARALLEL SAFE _COST_DEFAULT;
-CREATE OR REPLACE FUNCTION geom3d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
-	AS 'MODULE_PATHNAME','geom3d_brin_inclusion_add_value'
-	LANGUAGE 'c';
+CREATE OR REPLACE FUNCTION geom3d_brin_inclusion_add_value(internal, internal, internal, internal)
+RETURNS boolean
+AS 'MODULE_PATHNAME','geom3d_brin_inclusion_add_value'
-CREATE OR REPLACE FUNCTION geom4d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
-	AS 'MODULE_PATHNAME','geom4d_brin_inclusion_add_value'
-	LANGUAGE 'c';
+CREATE OR REPLACE FUNCTION geom4d_brin_inclusion_add_value(internal, internal, internal, internal)
+RETURNS boolean
+AS 'MODULE_PATHNAME','geom4d_brin_inclusion_add_value'
 CREATE OPERATOR CLASS brin_geometry_inclusion_ops_2d
Summary of changes:
 postgis/postgis.sql.in      |  4 ++--
 postgis/postgis_brin.sql.in | 45 ++++++++++++++++++++++++---------------------
 2 files changed, 26 insertions(+), 23 deletions(-)
hooks/post-receive
