[postgis-tickets] [SCM] PostGIS branch master updated. 6fbed378759eeec90413a372030e7312a6a66ea8
Mon Nov 18 11:21:10 PST 2019
the project "PostGIS".
       via  6fbed378759eeec90413a372030e7312a6a66ea8 (commit)
      from  d8a3b2ec4708752e770daabbaa38bd10e54b8d25 (commit)
revisions in full, below.
commit 6fbed378759eeec90413a372030e7312a6a66ea8
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 18 14:20:49 2019 -0500
    Dispense with using @extschema@ doesn't seem to be resolved in non-extension install and use instead location where postgis is installed, if it is installed. Also aadd end ; statement
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2b0c3d0..ae44b60 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2851,10 +2851,12 @@ BEGIN
 				 -- TODO: How do we tell if PostGIS Tiger Geocoder is available  ?
 			THEN
-				IF rec.name != 'postgis' THEN
-					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA @extschema@';
+				--force install in same schema as postgis only if postgis extension is installed
+				IF rec.name != 'postgis' AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
+					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
+					|| quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
 				ELSE
-					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged';
+					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged;';
 				END IF;
 				RAISE NOTICE 'Packaging extension %', rec.name;
 				RAISE DEBUG '%', sql;
Summary of changes:
 postgis/postgis.sql.in | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
