[postgis-tickets] [SCM] PostGIS branch master updated. eacf0c5188d99738840644de779b8fc26e1df999
Mon Nov 18 14:31:25 PST 2019
the project "PostGIS".
       via  eacf0c5188d99738840644de779b8fc26e1df999 (commit)
      from  6fbed378759eeec90413a372030e7312a6a66ea8 (commit)
revisions in full, below.
commit eacf0c5188d99738840644de779b8fc26e1df999
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 18 17:31:19 2019 -0500
    Don't try to set schema on extensions that have a schema specified (postgis_topology, postgis_tiger_geocoder).  References #4581
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ae44b60..c154fe9 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2852,7 +2852,7 @@ BEGIN
 				 -- TODO: How do we tell if PostGIS Tiger Geocoder is available  ?
 			THEN
 				--force install in same schema as postgis only if postgis extension is installed
-				IF rec.name != 'postgis' AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
+				IF rec.name NOT IN('postgis', 'postgis_topology', 'postgis_tiger_geocoder') AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
 					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
 					|| quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
 				ELSE
Summary of changes:
 postgis/postgis.sql.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
