[postgis-tickets] [PostGIS] #4583: windows build errors
trac at osgeo.org
Mon Nov 18 14:52:11 PST 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: buildbots | Version: master
Keywords: windows |
I'm seeing this on winnie, but I'm also having the same issue locally.
As far as I can tell this started happening sometime after Nov 10th
I switch back to pre GDAL 3.0 to rule that out but still having the same
issue.
/libxml/rel-libxml2-2.9.9w64gcc81/include/libxml2
-IE:/jenkins/postgresql/rel/pg12w64gcc81/include/server/port/win32
-DWIN32_STACK_RLIMIT=4194304 -c -o lwgeom_out_geojson.o
lwgeom_out_geojson.c
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wformat-
security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-
format-truncation -Wno-stringop-truncation -g -O2 -I../liblwgeom
-std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -flto -I../libpgcommon
-I../deps/wagyu -I../deps/uthash/include
-IE:/jenkins/geos/rel-3.8.0w64gcc81/include
-IE:/jenkins/proj/rel-6.2.1w64gcc81/include
-IE:/jenkins/protobuf/rel-3.2.0w64gcc81/include -I/projects/libxml/rel-
libxml2-2.9.9w64gcc81/include/libxml2 -I/projects/CGAL/rel-
sfcgal-1.3.2w64gcc81/include
-IE:/jenkins/json-c/rel-0.12w64gcc81/include/json-c
-IE:/jenkins/pcre/rel-8.33w64gcc81/include -DDLL_EXPORT -DPIC
-I/projects/CGAL/rel-sfcgal-1.3.2w64gcc81/include -I. -I./
-IE:/jenkins/postgresql/rel/pg12w64gcc81/include/internal
-I/projects/zlib/rel-zlib-1.2.11w64gcc81/include -I/projects/libxml/rel-
libxml2-2.9.9w64gcc81/include -I./src/include/port/win32 -DEXEC_BACKEND
-I/projects/libxml/rel-libxml2-2.9.9w64gcc81/include/libxml2
-DWIN32_STACK_RLIMIT=4194304 -c -o postgis_legacy.o postgis_legacy.c
format-truncation -Wno-stringop-truncation -g -O2 -shared -static-libgcc
-o postgis-3.dll postgis_module.o lwgeom_accum.o lwgeom_spheroid.o
lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
lwgeom_geos.o lwgeom_sfcgal.o lwgeom_geos_prepared.o lwgeom_geos_clean.o
lwgeom_geos_relatematch.o lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o
lwgeom_in_geohash.o lwgeom_in_geojson.o lwgeom_in_encoded_polyline.o
lwgeom_triggers.o lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o
lwgeom_functions_temporal.o lwgeom_rectree.o long_xact.o lwgeom_sqlmm.o
lwgeom_rtree.o lwgeom_transform.o lwgeom_window.o gserialized_typmod.o
gserialized_gist_2d.o gserialized_gist_nd.o gserialized_supportfn.o
gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
brin_2d.o brin_nd.o brin_common.o gserialized_estimate.o geography_inout.o
geography_btree.o geography_centroid.o geography_measurement.o
geography_measurement_trees.o geometry_inout.o postgis_libprotobuf.o
vector_tile.pb-c.o geobuf.pb-c.o mvt.o lwgeom_out_mvt.o geobuf.o
lwgeom_out_geobuf.o lwgeom_out_geojson.o postgis_legacy.o
-LE:/jenkins/postgresql/rel/pg12w64gcc81/lib -L/projects/zlib/rel-
zlib-1.2.11w64gcc81/lib -L/projects/libxml/rel-libxml2-2.9.9w64gcc81/lib
-Wl,--allow-multiple-definition -Wl,--disable-auto-import
-L/projects/libxml/rel-libxml2-2.9.9w64gcc81/lib -Wl,--as-needed
../deps/wagyu/libwagyu.la -lstdc++ ../libpgcommon/libpgcommon.a
../liblwgeom/.libs/liblwgeom.a -LE:/jenkins/geos/rel-3.8.0w64gcc81/lib
-lgeos_c -LE:/jenkins/proj/rel-6.2.1w64gcc81/lib -lproj
-LE:/jenkins/json-c/rel-0.12w64gcc81/lib -ljson-c
-LE:/jenkins/protobuf/rel-3.2.0w64gcc81/lib -lprotobuf-c
-L/projects/libxml/rel-libxml2-2.9.9w64gcc81/lib -lxml2 -liconv -lws2_32
-L/projects/CGAL/rel-sfcgal-1.3.2w64gcc81/lib -lSFCGAL -Wl,--exclude-
libs,ALL -Wl,--enable-auto-import
-L/projects/postgresql/rel/pg12w64gcc81/lib -L/projects/rel-
libiconv-1.15w64gcc81/lib -L/projects/zlib/rel-zlib-1.2.11w64gcc81/lib -lm
-flto -L/projects/CGAL/rel-sfcgal-1.3.2w64gcc81/lib -lSFCGAL -static-
libstdc++ -lstdc++ -Wl,-Bdynamic -lm
-LE:/jenkins/postgresql/rel/pg12w64gcc81/lib -lpostgres -lpgcommon
-lpgport -lxml2 -lz -lws2_32 -lm -lws2_32 -Wl,--export-all-symbols -Wl
,--out-implib=libpostgis-3.a
lto1.exe: internal compiler error: in gen_subprogram_die, at
dwarf2out.c:22668
libbacktrace could not find executable to open
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://sourceforge.net/projects/mingw-w64> for instructions.
lto-wrapper.exe: fatal error: C:\ming64gcc81\mingw64\bin\gcc.exe returned
1 exit status
compilation terminated.
C:/ming64gcc81/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/8.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe:
error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
make[1]: ***
[E:/jenkins/postgresql/rel/pg12w64gcc81/lib/pgxs/src/makefiles/../../src/Makefile.shlib:386:
postgis-3.dll] Error 1
make[1]: Leaving directory '/projects/postgis/branches/3.1/postgis'
make: *** [GNUmakefile:20: all] Error 1
3.0 branch seems to be fine but that one last ran in Nov 10th also.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4583>
