[postgis-tickets] [PostGIS] #4590: Upgrading PostGIS 3.0 PG 11 to PostGIS 3.0 PG 12 errors after pg_upgrade - st_linecrossingdirection
trac at osgeo.org
Tue Nov 26 01:43:35 PST 2019
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
> What's the deal, could you summarize what happened ?
It's explained above, the signature changed between 2.5 and 3.0 but only
for PG11 and before.
> Did we ship a broken version of PostGIS which changed signature without
adding a -- Changed comment ?
Yes and no. We shipped a PostGIS release that changed a signature without
adding a `-- Changed` comment on top. That doesn't mean it's broken.
> Changing the signature back means whoever installed the broken PostGIS
would fail upgrading again.
I didn't change the signature back, I changed it forward to match the one
used for PG11. Neither the signature is broken nor it will fail on upgrade
again as far as I can see.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4590#comment:7>
