[postgis-tickets] [SCM] PostGIS branch master updated. fa7aaf09a40b18e9ac508206e5fa2cb3ebf8fd2e
git at osgeo.org
git at osgeo.org
Tue Nov 26 06:08:32 PST 2019
the project "PostGIS".
via fa7aaf09a40b18e9ac508206e5fa2cb3ebf8fd2e (commit)
from 651add11bdb70ccb3b94cc640c99457bdc80f0dd (commit)
revisions in full, below.
commit fa7aaf09a40b18e9ac508206e5fa2cb3ebf8fd2e
Author: Mitchell Henke <mitchell at mitchellhenke.com>
Date: Mon Nov 25 10:02:35 2019 -0600
Fix a couple doc typos and reword for clarity
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index b7de2df..3e56367 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -2165,19 +2165,19 @@ WHERE
size, and the penalty in write workload. Otherwise, BRIN index can be
considered as an alternative. </para>
- <para>The idea of a BRIN index is to store only the bouding box englobing
+ <para>The idea of a BRIN index is to store only the bounding box enclosing
all the geometries contained in all the rows in a set of table blocks,
called a range. Obviously, this indexing method will only be efficient
- if the data is physically ordered in a way where the resulting bouding
+ if the data is physically ordered in a way where the resulting bounding
boxes for block ranges will be mutually exclusive. The resulting index
will be really small, but will be less efficient than a GiST index in
many cases.</para>
<para>Building a BRIN index is way less intensive than building a GiST
- index. It's quite common to build a BRIN index in more than ten time less
- than a GiST index would have required. As a BRIN index only store one
- bouding box for one to many table blocks, it's pretty common to consume
- up to a thousand time less disk space for this kind of indexes.</para>
+ index. It's quite common to build a BRIN index ten times faster
+ than a GiST index would have required. As a BRIN index only stores one
+ bounding box for one to many table blocks, it's pretty common to consume
+ up to a thousand times less disk space for this kind of index.</para>
<para>You can choose the number of blocks to summarize in a range. If you
decrease this number, the index will be bigger but will probably help to
Summary of changes:
doc/using_postgis_dataman.xml | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
