[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-84-g2e4e069
git at osgeo.org
git at osgeo.org
Mon Apr 27 15:56:19 PDT 2020
the project "PostGIS".
via 2e4e069479c02ec2a49b1e5fb6e4ad0eeb6cbe82 (commit)
from 430a5c3feb64ffb7dddd01a1f417a39f0bed39eb (commit)
revisions in full, below.
commit 2e4e069479c02ec2a49b1e5fb6e4ad0eeb6cbe82
Author: Regina Obe <lr at pcorp.us>
Date: Mon Apr 27 18:56:14 2020 -0400
Get rid of unneccessary CTE and also LATERAL keyword, just mention it's optional
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 4303aa2..99dbeda 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -851,6 +851,7 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
</imageobject></inlinemediaobject></para>
<para>Availability: 3.1</para>
+ <note><para>All calls in the examples use an implicit LATERAL construct although you don't see the LATERAL keywor. The LATERAL keyword is optional for set returning functions and is implied when using a input from prior table in the FROM.</para></note>
</refsection>
@@ -879,17 +880,11 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
<para>Tiling states results in a hexagon coverage of each state, and multiple
hexagons overlapping at the borders between states.</para>
- <programlisting>WITH hexes AS (
- SELECT admin1.gid, hex.geom
+ <programlisting>SELECT admin1.gid, hex.geom
FROM admin1
- CROSS JOIN LATERAL ST_HexagonGrid(100000, admin1.geom) AS hex
+ CROSS JOIN ST_HexagonGrid(100000, admin1.geom) AS hex
WHERE adm0_a3 = 'USA'
-SELECT hexes.*
-FROM hexes
- INNER JOIN admin1 ON hexes.gid = admin1.gid
-WHERE ST_Intersects(admin1.geom, hexes.geom)
-</programlisting>
+ AND ST_Intersects(admin1.geom, hex.geom)</programlisting>
</refsection>
<refsection>
<title>See Also</title>
Summary of changes:
doc/reference_constructor.xml | 13 ++++---------
1 file changed, 4 insertions(+), 9 deletions(-)
hooks/post-receive
