[postgis-tickets] [PostGIS] #4734: Debbie failing regress raster on gdal_polygonize and raster_surface on GDAL 3.2 and 3.1 (was: Debbie failing regress on gdal_polygonize on GDAL 3.2 and 3.1)
trac at osgeo.org
Sun Aug 2 18:18:03 PDT 2020
3.2 and 3.1
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GDAL
Component: buildbots | Version: master
Resolution: | Keywords:
Description changed by robe:
Old description:
> I had switched debbie to testing with GDAL 2.4 on PostGIS Master because
> GDAL 3.1 was failing. Just retested with GDAL 3.2 (master) and still
> failing. Can't find the original ticket I put in.
> I'm not sure if it's proj or what.
> 20:28:35 Suite: gdal
> 20:28:35 Test: test_gdal_configured ...passed
> 20:28:35 Test: test_gdal_drivers ...passed
> 20:28:35 Test: test_gdal_rasterize ...passed
> 20:28:35 Test: test_gdal_polygonize ...FAILED
> 20:28:35 1. cu_gdal.c:180 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3
> 1,3 2,2 2,2 3,1 3,1 6,2 6,2 7,3 7,3 8,5 8,5 6,3 6,3 3,4 3,5 3,5 1,3 1))")
> 20:28:35 2. cu_gdal.c:196 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0
> 0,0 9,9 9,9 0,0 0),(6 7,6 8,3 8,3 7,2 7,2 6,1 6,1 3,2 3,2 2,3 2,3 1,6 1,6
> 2,7 2,7 3,8 3,8 6,7 6,7 7,6 7))")
> 20:28:35 3. cu_gdal.c:232 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0
> 20:28:35 4. cu_gdal.c:260 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0
> 20:28:35 5. cu_gdal.c:264 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3
> 20:28:35 6. cu_gdal.c:295 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3
> 20:28:35 7. cu_gdal.c:327 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3
> 20:28:35 8. cu_gdal.c:343 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0
> 20:28:35 Test: test_raster_to_gdal ...Warning 6: PNG driver doesn't
> support data type Float64. Only eight bit (Byte) and sixteen bit (UInt16)
> bands supported. Defaulting to Byte
> 20:28:35 Test: test_raster_surface ...INFO: Self-intersection at or
> near point 2 -2
> 20:28:35 INFO: Self-intersection at or near point 2 -2
> 20:28:35 FAILED
> 20:28:35 1. cu_raster_geometry.c:296 -
> CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 0,1 -1,0 -1,0 -5,4 -5,5 -5,5
> 0,1 0)))")
> 20:28:35 2. cu_raster_geometry.c:308 -
> 0,1 0),(1 -1,1 -2,2 -2,2 -1,1 -1)))")
> 20:28:35 3. cu_raster_geometry.c:321 -
> CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0
> -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))")
> 20:28:35 4. cu_raster_geometry.c:335 -
> -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3
> -4,4 -4,4 -3,3 -3)))")
> 20:28:35 5. cu_raster_geometry.c:363 -
> CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -4,2 -4,2 -3,3 -3,3 -4,4
> -4,4 -5,3 -5,1 -5,1 -4)),((1 -4,0 -4,0 -1,1 -1,1 -2,2 -2,2 -3,1 -3,1
> -4)),((3 -2,4 -2,4 -1,5 -1,5 -4,4 -4,4 -3,3 -3,3 -2)),((3 -2,2 -2,2 -1,1
> -1,1 0,4 0,4 -1,3 -1,3 -2)))")
New description:
20:24:34 -------------- Dependencies --------------
20:24:34 GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.9w64/bin/geos-config
20:24:34 GEOS version: 3.9.0dev
20:24:34 GDAL config:
/var/lib/jenkins/workspace/gdal/rel-3.2w64/bin/gdal-config
20:24:34 GDAL version: 3.2.0
20:24:34 SFCGAL config: /usr/bin/sfcgal-config
20:24:34 SFCGAL version: 1.3.7
20:24:34 PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg12w64/bin/pg_config
20:24:34 PostgreSQL version: PostgreSQL 12.3
20:24:34 PROJ4 version: 71
20:24:34 Libxml2 config: /usr/bin/xml2-config
20:24:34 Libxml2 version: 2.9.10
20:24:34 JSON-C support: yes
20:24:34 protobuf support: yes
20:24:34 protobuf-c version: 1003003
20:24:34 PCRE support: no
20:24:34 Perl: /usr/bin/perl
20:24:34 Wagyu: yes
20:24:34
20:24:34 --------------- Extensions ---------------
20:28:35 Test: test_raster_surface ...INFO: Self-intersection at or near
point 2 -2
20:28:35 FAILED
0,1 0)))")
CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -4,2 -4,2 -3,3 -3,3 -4,4 -4,4
-5,3 -5,1 -5,1 -4)),((1 -4,0 -4,0 -1,1 -1,1 -2,2 -2,2 -3,1 -3,1 -4)),((3
-2,4 -2,4 -1,5 -1,5 -4,4 -4,4 -3,3 -3,3 -2)),((3 -2,2 -2,2 -1,1 -1,1 0,4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4734#comment:2>
