[postgis-tickets] [PostGIS] #4734: Debbie failing regress raster on gdal_polygonize and raster_surface on GDAL 3.2 and 3.1
PostGIS trac at osgeo.org
Sun Aug 2 19:14:06 PDT 2020
3.2 and 3.1
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS GDAL
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by robe):
 Okay I was mistaken.  GDAL 3.1 branch is fine.  Just GDAL_Master (upcoming
 3.2).
 I think that rules out Proj since both are Proj 7.0
 22:00:15  -------------- Dependencies --------------
 22:00:15   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.9w64/bin/geos-config
 22:00:15   GEOS version:         3.9.0dev
 22:00:15   GDAL config:
 /var/lib/jenkins/workspace/gdal/rel-3.1w64/bin/gdal-config
 22:00:15   GDAL version:         3.1.2
 22:00:15   SFCGAL config:        /usr/bin/sfcgal-config
 22:00:15   SFCGAL version:       1.3.7
 22:00:15   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg12w64/bin/pg_config
 22:00:15   PostgreSQL version:   PostgreSQL 12.3
 22:00:15   PROJ4 version:        71
 22:00:15   Libxml2 config:       /usr/bin/xml2-config
 22:00:15   Libxml2 version:      2.9.10
 22:00:15   JSON-C support:       yes
 22:00:15   protobuf support:     yes
 22:00:15   protobuf-c version:   1003003
 22:00:15   PCRE support:         no
 22:00:15   Perl:                 /usr/bin/perl
 22:00:15   Wagyu:                yes
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4734#comment:3>
