[postgis-tickets] [PostGIS] #4736: ST_NumGeometries is zero for GeometryCollection with empty parts
trac at osgeo.org
Tue Aug 4 21:06:51 PDT 2020
Reporter: Mike Taves | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.4.x
Keywords: |
Take a !GeometryCollection with mixed empty/non-empty parts:
db=> select ST_IsEmpty(g), ST_NumGeometries(g), ST_AsText(g),
ST_AsText(ST_GeometryN(g, 1)), ST_AsText(ST_GeometryN(g, 2))
db-> from (select 'GeometryCollection(Point empty, point(1 2), LineString
empty)'::geometry g) f;
-[ RECORD 1
st_isempty | f
st_numgeometries | 3
st_astext | GEOMETRYCOLLECTION(POINT EMPTY,POINT(1 2),LINESTRING
EMPTY)
st_astext | POINT EMPTY
st_astext | POINT(1 2)
that seems fine. Now with two empty parts:
db-> from (select 'GeometryCollection(Point empty, LineString
-[ RECORD 1 ]----+-------------------------------------------------
st_isempty | t
st_numgeometries | 0
st_astext | GEOMETRYCOLLECTION(POINT EMPTY,LINESTRING EMPTY)
st_astext | LINESTRING EMPTY
why is ST_NumGeometries now suggesting there are zero geometries, but
ST_GeometryN is able to retrieve the two empty parts? An expected result
would have ST_NumGeometries return 2 instead of 0.
postgis_full_version | POSTGIS="2.4.0 r15853" PGSQL="96"
GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
1.11.4, released 2016/01/25" LIBXML="2.9.1" LIBJSON="0.11" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4736>
